I am working on a project in which I need an LED to turn on a low setting when a momentary switch is pressed once. I need the LED to turn on a high setting when the momentary switch is pressed twice in quick succession. The LED should be turned off by pressing the momentary switch again.
I have seen this in high powered flashlights and am trying to replicate it.
I believe this requires an IC chip, but I have spent hours online trying to find information on this with no luck.
