Object counter
DerStrom8
Joined Feb 20, 2011
2,390
still invalid file
Try sending it to a zipped folder, and upload that. The site here doesn't accept multisim files--it doesn't recognize the file extension. You need to send it using a file extension that the site recognizes, like .zip. Just right-click on the file you're trying to send, chose send to-->compressed (zipped) folder, and when it's finished compressing upload the zipped folder here.
DerStrom8
Joined Feb 20, 2011
2,390
What's your file format?
The valid file extensions: asc bin bmp brd doc gif hex jpe jpeg jpg lbr pdf png psd sch sub txt zip.
The file format for a multisim project is usually .msxx, where xx is the version. You need to somehow put it in a file that has a supported format. In order to keep the active project, the best way to do this is to put it in a .zip file.
ScottWang
Joined Aug 23, 2012
7,505
For the circuit to view on the forum that using gif or png is better, and the format of his file is a jpg on the web, so I transfer to a gif that it's also reduce the space of the file.
DerStrom8
Joined Feb 20, 2011
2,390
The point was that the OP was trying to send a multisim file, so that others could see the actual simulation. I don't think the focus is on the circuit itself, but on the operation of it. That's why he needs to send the actual multisim file, not just a picture of it.
ScottWang
Joined Aug 23, 2012
7,505
Yes, you are right.
