Superheterodyne Receiver Book
KCHARROIS
Joined Jun 29, 2012
312
I am in the need of a book that could teach me how to design a superheterodyne receiver or at least something that could show me how to designs pieces of the superheterodyne receiver. Any books you guys have in mind?
cork_ie
Joined Oct 8, 2011
428
There are lots and lots of Superhet circuits available online. I doubt you will need to buy a book.
I would start by looking at some of the older Valve (Tube) radio designs as they are generally simpler and easier to understand.
KCHARROIS
Joined Jun 29, 2012
312
Yes but I need a book to help me design one or how to design the parts of a superheterodyne receiver such as mixer, local oscillatr, rf amp, demodulator, etc.
Wendy
Joined Mar 24, 2008
23,800
The basics all exist pretty much individually, and can be looked up on the internet with great ease.
However, if you need a paper book, think amateur radio. HAMs do this stuff routinely.
KCHARROIS
Joined Jun 29, 2012
312
Hello again,
Ok so I've looked at few links and have to decided I'd like to build a superheterodyne AM receiver. Most circuit I see seem to use IC's, but usualy before I use IC's i build something with discrete components to prove to myself I learned something. I do understand the topology behind superheterodyne receivers but I dont know how to design them. Is it worth trying to build something with discrete components or should I stick using IC's with some discrete components?
vk6zgo
Joined Jul 21, 2012
677
The ARRL Handbook,or RSGB Manual,especially older ones,have quite a lot on Superheterodynes.
The Superheterodyne principle is the single most important circuit design concept utilised in RF Communications Electronics.
It is used in almost all aspects of that industry.
Although other methods are being used,they are still in the minority,compared to the equipment using the Superheterodyne principle.
After all,a Direct Conversion (D.C.) Receiver is just like a Superhet,except that it has a zero frequency IF.
A Digital direct sampling receiver also uses many of the same concepts.
Sampling?,mixing?--very much the same thing,looked at from a different perspective.
If you have a signal generator,& can make up,or obtain a mixer,you can begin to get hands on experience with the building blocks of Superhets.
A good start is to make a HF converter to use with a MW AM radio,using the above bits.---it will be "as rough as guts",& won't work at all well,but you'll be learning.
KCHARROIS
Joined Jun 29, 2012
312
Ok so I look at these links and I cant tell you how confusing everything looks. I'm currently going to niagara college and the only thing I've learned in RF is the topology of most transmitters and receivers. I understand there building blocks on what each part does but nothing on designing them and putting it all together to make a receiver or transmitter. I feel like rf is out of my league how long did it take for you guys to design one? What kind of education did u get to design one? Are there online courses i could take?
Wendy
Joined Mar 24, 2008
23,800
The trick with any design is to break it down. The hetrodyne circuit is the only really odd part with this radio.
Have you seen a block diagram of a superhetrodyne radio?
Have you ever built a crystal radio? This applies, because (believe it or not) this section is in almost every AM radio built.
KCHARROIS
Joined Jun 29, 2012
312
I do understand the building blocks of a superheterodyne receiver, I just dont know how to design each section and then adding it all together. And no I have never built a crystal radio.
http://www.mikroe.com/old/books/rrbook/rrbook.htm
This link is great for me because it identifies every piece. For the simples AM superheterodyne receiver section I understand that the incoming signal is mixed with the oscillator to produce an IF of 455 KHz whihc is a standard and then it goes throu a filter designed for a certain bandwidth suppressing all other incoming signals. And then it goes through the demodulator and then amp and then speakers. The part that confuses me the most is the Local oscillator piece and the MFT filter section. If I could understand what component he used and how they work, I believe this you'd give me a good reference point to move on.
KCHARROIS
Joined Jun 29, 2012
312
So I started looken at VCO's typically using the colpits fprmat with the use of a varactor to control the frequency. I've attached the picture of the circuit im analyzing.
What I understand is the Varactor and Inductor determine frequency, C1 blocks DC but what I dont seem to get are the other 2 capacitors from the base to emitter, I know they give the circuit feedback that keeps the oscillator going but what values do you choose for them?
Thanks in advance
panic mode
Joined Oct 10, 2011
5,112
vk6zgo
Joined Jul 21, 2012
677
Many of us know a lot about Receivers & Transmitters.
We have built them from other people's designs,fixed commercially made ones when they have failed,& indeed,immersed ourselves,at one time or another,in the circuitry involved,but probably only a few of us have designed either from scratch.
Don't get too bogged down on the "building blocks" approach.
Although it is a quite useful idea,remember that the Radio is one device,so you should keep in mind how each "block" works with the other ones.
The Blocks in "Block Diagrams" may not correspond to how you would separate the bits into "blocks",prior to putting them together.
I think you are over-analysing things.
Just for now,assume an "oscillator is an oscillator",& the niceties of the oscillator circuit don't really matter in your understanding of a Superheterodyne circuit.
This is why I suggested you use a Signal Generator as your Local Oscillator for your first few forays into this kind of Receiver.
OK,if you particularly want to study oscillators as a separate thing,get into the "nitty-gritty" of them then.
vk6zgo
Joined Jul 21, 2012
677
Thanks in advance
Wait! There's more!!:D
The "other 2 capacitors" are in fact the capacitive part of the LC circuit.
The varactor just "trims" the frequency.
The formula which you can use to determine their value appears here:-
http://en.wikipedia.org/wiki/Colpitts_oscillator#Oscillation_frequency
Note:- Just about every website has an infatuation with Common Base Colpitts circuits,but the Maths are the same for your circuit.
