I took 2 chips MAXIM MAX232 for my project but there is a prolem when I check MAX232 for test.I have tied capacitors like that attached in this post BUT i do not used capacitors like datasheet.All capacitors is 10uF rather than 1uF like datasheet.When i tied 11 pin(Tin with TTL level) to GND and then measure the voltage at 14 pin(232 output) I have read a value is 4.6V.I think It should be at -10V (232 standard).I have try 2 chips but they are same, with wrong conversion.Do you know this chip is not work?OR this is the problem of the capacitors that I had used.Do i really need to used all 1uF capacitors like datasheet.Could you expain me the value and how these capacitor is used.Thanks.
