Monoblocus is an high-end mono amplifier, capable of delivering up to 45W to 4Ohm loads and up to 29W to 8Ohm loads. This amplifier has a muting on power-off function, that mutes it once the same is turned off. For that, it uses an optocoupler, a TLP521-1. This makes this project very unique and quite interesting. Note that this project is not recommended to beginners, since it uses the mains. The project eventually can be adapted to work with 115V~: all you need to do is to use a 120VA transformer suitable for 115V~, and a proper primary fuse (the secondary fuses won't change).
List of components:
C1/4 – 10mF electrolytic capacitor (50V);
C2/5/7 – 100µF electrolytic capacitor (50V);
C3/6/11 – 100nF polyester capacitor (63V);
C8 – 1µF polyester capacitor (63V);
C9 – 220pF ceramic capacitor (63V);
C10 – 22µF non-polarized electrolytic capacitor (6,3V);
D1-4 – 1N5400 rectifier diode;
D5/6 - 1N4001 rectifier diode;
F1 – 1A slow-blow fuse;
F2/3 - 3.15A slow-blow fuse;
HS – 1.2°C/W passive heatsink;
IC1 - TLP521-1 optocoupler;
IC2 – LM3876 audio power amplifier (LM3876TF);
J1 – IEC C14 connector;
J2 – RCA female connector;
JW – 26AWG stranded wire;
L - Air core coil, 16 turns with 6mm dia. of 22 AWG wire;
LP – 230V~ resistored neon bulb;
R1 – 1.2KR carbon resistor (5% tol., 1W);
R2/6 – 33KR carbon resistor (5% tol., 1/8W);
R3 – 12KR carbon resistor (5% tol., 1/8W);
R4 – 47KR carbon resistor (5% tol., 1/8W);
R5/7 – 1KR carbon resistor (5% tol., 1/8W);
R8 – 2,7R carbon resistor (5% tol., 2W);
R9 – 10R carbon resistor (5% tol., 1/2W);
S – DPST switch;
T – Toroidal transformer 230V~ pri. 2x18V~ sec. 120VA.
Electrical parameters:
- Va min = 207V RMS
- Va max = 253V RMS
- Ia (Va = 230V RMS, Z = 4Ohm) = 496.4mA RMS
- Ia (Va = 230V RMS, Z = 8Ohm) = 343.9mA RMS
- P (Va = 230V RMS, Z = 4Ohm) = 114.2W
- P (Va = 230V RMS, Z = 8Ohm) = 79.10W
Amplification characteristics:
- Input impedance: 9.559KOhm
- Input sensitivity: 500mV RMS
- Gain: 30,63dB (34V/V)
- Frequency response (-3dB): 27.19-120000Hz
- Output power (Z = 4Ohm): 45W
- Output power (Z = 8Ohm): 29W
List of components:
S – DPST switch;
- Va min = 207V RMS
- Va max = 253V RMS
