Help.... i'm newbie, ic 4093, CD4093, HCF4093 library
ednietoz
Joined Mar 14, 2011
hello guys...i am newbie for diptrace...i learn hard to try making schematic with diptrace....in my first project i try to draw 220v/2000 watt stabilizer with ic 4093......when i tried to put component from library i cant find ic 4093 in all library manufacture list...i try to find another equivalent ic 4093 in library,they are HCF 4093, CD4093, MC14093 but still cant find it...would you please to help me guys...i would like to learn more from all off you.......thx for help..........
BillB3857
Joined Feb 28, 2009
2,573
Some say the best way to learn to swim is to jump feet first into the deep end with no lifeguard. Darwin principle at work!
ednietoz
Joined Mar 14, 2011
Welcome to the forums.
Please don't hijack existing threads with a new question - http://forum.allaboutcircuits.com/showthread.php?t=55853
If you are looking for a quad two input Schmitt trigger NAND gate, then you will find that a CD4093 and an MC14093 are identical IC's.
I suspect you may be dangerously over your head in this project.
sorry for m stupid post sir....i'm still new and i not quite good in english.......i will try better....
SgtWookie
Joined Jul 17, 2007
22,230
I have never used DIPTRACE, nor read the instructions for its' use.
If you cannot find an x4093B IC in the library, you might simply use a generic IC package that has the same number of pins (14) that the x4093B has.
