How are double sided pcb's soldered in a reflow oven?
danforth
Joined May 8, 2011
22
So you apply solder paste to one side, place your components, heat and reflow in oven. When you do the same to the other side, won't the components fall off the opposite side from gravity?
What is a good way to do this?
#12
Joined Nov 30, 2010
18,224
I keep finding glue dots under the components I remove from circuit boards. Or, If I may quote the above link, "a teeny dot of epoxy".
ErnieM
Joined Apr 24, 2011
8,415
Well, I have two ways of doing it.
The second way was made necessary when my company shipped my beautiful reflow over an 8 hour drive away. I have here a small desktop "spinner" as I call it, 6 arms that rotate, half the base is formica and the other half is three sections of "hot plates," pre-heat, reflow, cool-down. You place a part before an arm and it is swept through the 3 zones and gets left on the formica all nicely reflowed.
Of course it is useless for double sided boards as it will wipe off all the parts on the "other side." So I use it for one side, then use a heat gun for the other.
My preferred method is a chain belt reflow oven. You put parts in one end and they come out the other. Generally you place parts on a "boat," some sort of solid surface to keep them off the belt. We have lots of ceramic substrates lying about so I use them, but even a bare PC board would do.
Now the thing about double sided boards is... I don't do anything special. Just put the parts in with the side already reflowed down, and reflow the top. Small parts get held in place by the surface tension of the solder. I've never had a part heavy enough to fall off, but if they do then those would get glued down.
One reflow oven I saw only had a heating element on the top side in the reflow section, this would keep the bottom a little cooler and perhaps not go to reflow.
THE_RB
Joined Feb 11, 2008
5,438
The chain ovens normally use IR radiating elements on the top side, so as speed and temps are controlled quite precisely the top only gets hot enough to flow for a few seconds and the bottom always remains quite a few degrees cooler (doesn't melt bottom solder).
You can do similar thing at home by using a electric frypan on low heat to preheat the PCB and bring it near the solder flow temp then a few seconds of hot air gun on top to flow the top of PCB, and it's actually a pretty good way to do SMD for home use in general.
atferrari
Joined Jan 6, 2004
5,022
Hola RB,
Could you elaborate? I hate the idea to build it (buying locally would be impossible because $$ and Customs regulations about anything using above 24V supplies).
I mean, how to control (kitchen-table environment is possible?l) the temperatures and all that. Gracias.
russpatterson
Joined Feb 1, 2010
353
I've had good luck just using a toaster oven with a temp sensor inside. I put a blob of solder paste on some copper right in front by the window. When the blob turns silver and spreads out... count to ten then turn the temp down on the toaster and let it cool. Then do the other side of the board. The parts on the bottom stay on. There's some good articles and products here but I think the controller is over-kill.
http://www.sparkfun.com/search/results?term=oven&what=tutorials
http://www.sparkfun.com/datasheets/Widgets/ToasterOven-UserManual.pdf
THE_RB
Joined Feb 11, 2008
5,438
I used to use a toaster oven and still have my little oven in the workshop. But the trouble is the "hot spots" near elements and cooler areas elsewhere (normally the element is like a square loop). There is also the hassle of visibility as it's all inside a dark metal box, and hassle to open/close doors etc.
If you use an electric frypan it has a lot of metal mass that gets a pretty even temperature, and access, lighting and visibility is very good. You can also put a piece of thermal mass in there like a 6" square ceramic tile or piece of flat metal. This evens out all the hot spots and gives a constant "plate temperature" to sit the PCB on.
Then you use the frypan for the preheat, usually 120'c or so for a minute (see temperature charts on google etc) so the whole PCB is hot but well below melt point. This dries moisture and reduces thermal shock.
Then use a fan heat gun or hair dryer (reduce fan air flow if needed with restrictions so it doesn't blow stuff around) to heat the top of the boards. With the good lighting and top access you can get your face right over it and easily see the melt flow occur after a few seconds (maybe 10 seconds to get to melt point?), then a few seconds after melt just turn the heat gun off.
The frypan has a heat adjust knob to set it's preheat temperature and the heat gun air heat is controlled by how close you put it over the top of the PCBs. I works very well, I probably won't use my toaster oven again...
WBahn
Joined Mar 31, 2012
33,109
You are replying to long dead threads with posts that amount to site promotion, which is not allowed. The fact that your content is directly related and relevant to the thread discussion puts this on the fence. But, please, there really isn't much point in reviving threads that have been dormant for so many years.
