I've a problem with my Accelerometer in my I2C program(PIC32)
Sielo
Joined May 26, 2011
Hi, first of all i'm sorry for my english i hope u can undestand what i'll say.
I'm having problem with my program, i'm trying to do a balancing robot with acc and gyro using PIC32 and I2C.
I tested this I2C routine and it seems to work but something mess up with the data that i read with my acc i've done a cycle to test the ±G switching by moving my platform,it seem to "fall" always by the same side.
The acc i'm using is MMA7455L.
And this is the data sheet link http://www.freescale.com/files/sensors/doc/data_sheet/MMA7455L.pdf
Sorry for some italian comment but i think the I2C routine doesn't need comment i've comment in english only Cmotory,Inizacc and Elabacc.
This is my Code:
Rich (BB code):
#include<plib.h>
#include<peripheral/int.h>
#include<p32xxxx.h>
#pragma config POSCMOD=XT, FNOSC=PRIPLL
#pragma config FPLLIDIV=DIV_2, FPLLMUL=MUL_18, FPLLODIV=DIV_1
#pragma config FPBDIV=DIV_2, FWDTEN=OFF, CP=OFF, BWP=OFF
#define LCDDATA 1
#define LCDCMD  0
#define PMDATA  PMDIN
int len,reg_addr,PER_ADDR,Dgyro,Dacc,Dgyroold,DgyroM,Direz;
unsigned char dato;
void configPIC ()
#define SYSTEM_CLK (80000000L)
SYSTEMConfigPerformance(SYSTEM_CLK);
mJTAGPortEnable(DEBUG_JTAGPORT_OFF);  // JTAG disabled
TRISE=0x00;         // Set TRISE to all output
LATE=0x00;         // Init all the E pin to 0
void eepromInit(void)
I2CConfigure(I2C2, I2C_ENABLE_SLAVE_CLOCK_STRETCHING|I2C_ENABLE_HIGH_SPEED);
I2CSetFrequency(I2C2,80000000L,40000);           //Set the F=4Khz
I2CEnable(I2C2, TRUE);                                   //I2C Enable
void eepromRead(unsigned int PER_ADDR, unsigned int reg_addr,unsigned char *buf)
StartI2C2();           //Avvio L'I2C
IdleI2C2();            //Metto in idle aspettando un nuovo comando
MasterWriteI2C2(PER_ADDR | 0);       //Chiamo la periferica desiderata in scrittura
IdleI2C2();
if (I2C2STATbits.ACKSTAT)return;      //Controllo se è ritornato un ack se no rinizio la procedura
MasterWriteI2C2(reg_addr);        //Chiamo il registro interno alla perifica
IdleI2C2();
if(I2C2STATbits.ACKSTAT) return;      //Controllo se è ritornato un ack se no rinizio la procedura
RestartI2C2();           //Eseguo un Restart per poter chiamare la funzione in lettura altrimenti creerei un situazione di conflitto sui bus
IdleI2C2();
MasterWriteI2C2(PER_ADDR | 1);       //Chiamo la periferica desiderata in lettura
IdleI2C2();
I2C2CONbits.RCEN = 1;
while(!DataRdyI2C2());         //Inizio ricezione dati
*buf = I2C2RCV;           //Metto i dati nel buffer
I2C2CONbits.ACKDT = 1;
I2C2CONbits.ACKEN = 1;
while(I2C2CONbits.ACKEN==1);       //inizio la procedura di ack per arrivare alla fine della trasmissione
StopI2C2();
IdleI2C2();
void eepromWrite(unsigned int PER_ADDR, unsigned int reg_addr, unsigned char *buf)
 StartI2C2();
 IdleI2C2();
 MasterWriteI2C2(PER_ADDR | 0);           //Chiamo la periferica in scrittura
 IdleI2C2();
 if (I2C2STATbits.ACKSTAT)return;    //Richiedo un ack
 MasterWriteI2C2(reg_addr);               //Invio l'indirizzo del registro della periferica
 IdleI2C2();
 MasterWriteI2C2(*buf);       //Scrivo il dato inserito nella variabile puntata da buf
 IdleI2C2();
  StopI2C2();
  IdleI2C2();
 while(1)
  StartI2C2();
  IdleI2C2();
  IdleI2C2();
 if (I2C2STATbits.ACKSTAT==0) break;   //Se ritorna un ack esco dal ciclo
  StopI2C2();
  IdleI2C2();
 StopI2C2();
 IdleI2C2();
void Inizacc ()
 int indirizzo=0x3A;
 dato=0b00000101;
 eepromWrite(indirizzo,0x16,&dato);     //2G mode
 dato=0b00000000;
 eepromWrite(indirizzo,0x18,&dato);     //All axis enable
 dato=0b00000000;
 eepromWrite(indirizzo,0x19,&dato);     //Motion Detector
void Elabacc ()
 int indirizzo=0x3A;
 eepromRead(indirizzo,0x08,&dato); //Z axis 8 bit, only one avaible in measurament mode
 Dacc=dato;
void CMotori ()
 int Stab;
 Stab=Dacc;                    //Var to avoid activating motors while in stability
 if(Stab=0) return;
 Direz=Dacc && 0x80;     //Mask MSB to compare it (MSB change with the G polarity +G=0 -G=1).
 if (Direz = 0)
  while(Direz=0)             //while falling one that side.
  LATEbits.LATE0=1;        //Enable the motors supply and direction
  LATEbits.LATE1=1;
  LATEbits.LATE2=0;
  Elabacc();                       //Check the acc data
  Direz=Dacc && 0x80;     //Put new data in direz
 else
  while(Direz=0x80)        //same as before but for other side
  LATEbits.LATE0=1;
  LATEbits.LATE1=0;
  LATEbits.LATE2=1;
  Elabacc();
  Direz=Dacc && 0x80;
main (void)
 configPIC();
 eepromInit();
 Inizgyro();               //function removed in this because i'm sure that's right and i don't use it in this example
 Inizacc();
 while(1)
 Elabacc();
 CMotori();
ErnieM
Joined Apr 24, 2011
8,415
I'm just taking a wild guess here.
in void Elabacc () you perform
Dacc=dato;
where dato is a char and Dacc is an int.
Later in void CMotori () you perform:
Now depending on your compiler you may need to do something different, see if you can hook a debugger on there to see what values you actually have. It may be that converting the char dato to the int Dacc is extending the sign bit across the full width of the int.
Sielo
Joined May 26, 2011
i'm using MPLAB tomorrow morning i'll try because now it's a bit late for me
I'll let u know if it works!
Thank you for the help ^^
Sielo
Joined May 26, 2011
It wasn't a problem of Char or int!
I'm an idiot... i've done && to do normal AND instead of & and = to compare instead of == now it works!
