show your picture,one by one
Wendy
Joined Mar 24, 2008
23,809
Want to see my picture? Look at my profile. Want the background story about it? Read my blog, "PaintCAD and Introduction". Want to access my blog? Click the little blue number right under post count. Couldn't be simplier.
nerdegutta
Joined Dec 15, 2009
2,689
Maybe a solarpanel could do the same job... (Here I'm sitting with my ignorance believing theres always sunshine in Africa, while I'm preparing myself to go out and shuffle the snow that came last night)
nerdegutta
Joined Dec 15, 2009
2,689
With your climate you need to copy the creative solution of our friend soda. :D
I bought this: Ariens and I'm very happy about it. As for the creativity, I would like to install some kind of heating system in my drive way. I do not like moving snow. Or I could set up this kind of ad:
But I think I would be stuck until spring... :(
{ed}
Drifting off topic again...
{/ed}
Kermit2
Joined Feb 5, 2010
4,159
... I would like to install some kind of heating system in my drive way. I do not like moving snow.
If you are lucky enough to have the hot water heater in the garage and you possess a lawn/garden water hose and a sprinkler. You may have already guessed what I'm going to tell you. Connect the water hose to the little drain spigot on the side. Run the hose out to the driveway and hook up the sprinkler. Turn on the drain valve just a little, enough to get the sprinkler going in the small area of the drive way. Running at low rate it can go for 15 to twenty minutes before it cools off to much. A ten minute break and it should be hot enough to run again if you need it that soon. (Ghetto driveway de-icer)
(When you actually drain a hot water heater you shut off the water inlet, this is using the drain as just another faucet on the line. The water inlet should not be shut off.)
1940's
That's me as a world war two corporal in the motor pool. :)
loosewire
Joined Apr 25, 2008
1,686
Happy,the China ballet dancer you posted Is a good Image
to keep our minds at work. You would be best not to post
another Image . Maybe later, do you understand.
happyganl
Joined Dec 17, 2009
157
:confused: really? and I didnt say that dancer its me.
yeas ago,I only like people who looks handsome
now I think funny, kind,humor people are the most attractive:p
