I have recently aquired a used traffic signal, and am wanting to wire it to where each individual light turns on and off in succession. I understand that I need to use a timed relay in order to achieve this goal, but after searching the web, I have become overwhelmed with too much technical info. I will be running the signal off of 120V ac. Is there anyone out there that can suggest what exact parts (less expensive the better) I need and how I need to wire this in to achieve "revolving" lights. I already have the light wired and running with all three colors burning at once. Thanks for your thoughts and imput.
