Then you have to work with board houses and Gerber files. Placing symbols on a PCB e.g approval, warning and recycle markings. Say on the silkscreen layer. May not be so easy in all PCB software. Some tools support this in a more or less awkward fashion. And things like scaling and rotating may be hard. But almost all PCB tools support TTF type fonts, and allow both scaling and rotation. So I have made a TTF font containing symbols that might be useful for PCB designers. I have worked on this project for while adding new symbols sorting etc. But I guess some people will need symbols not included yet. So I include my drawing file as a template. I have used Corel Draw version 10. And also information on these sites. But any font editor software may do the job.
http://coreldesigner.wordpress.com/2009/03/06/create-your-own-custom-fonts-using-coreldraw-part-i/
http://coreldesigner.wordpress.com/2009/03/18/create-your-own-font-designs-using-coreldraw-part-ii/
http://theboutons.com/cdr-x6-exercise-files/X6_Bonus_Chapter1_Fonts.pdf
So what is a TTF font. A TTF font is a collections of vector images, i.e. a set of lines and curves to define it. To create a TTF fonts you use outline drawings. As an example these drawings
Will look like this then printed as fonts
It is also possible to draw more advanced pictures as outlines The picture below is an example of that. Then I created the PCB font. I most often used Google to search vector based graphic artwork. Then I imported the graphic into Coreldraw to do the touchup. Like converting solid lines to outline figures.
