Problem with output power-linear amplifier
tzitzikas
Joined Jun 3, 2007
41
hi, i have construct this linear amplifier for mw band: http://tzitzikas.webs.com/linear500w.jpg with 12 mosfets IRFP360.
some photos from my project here:
http://tzitzikas.webs.com/linear_photo_1.jpg
http://tzitzikas.webs.com/linear20.JPG
http://tzitzikas.webs.com/linear20a.JPG
http://tzitzikas.webs.com/linear21.JPG
http://tzitzikas.webs.com/fet21.JPG
http://tzitzikas.webs.com/pompos20.JPG
http://tzitzikas.webs.com/T3.JPG (photo of /t3 broadband transformer)
for ferrite beads i am using FB-43-7351 from https://www.amidoncorp.com/items/44 but i have also orderedFB-43-7352 and the FB-43-1020 ferrite beads.
The manufacturer claims that with only 2w input r.f power it gives 500w at the output at 110vdc (13A current). But with 5,5w input power at 106vdc my linear gives only 220w output r.f power (7A current) at dummy load 50ohm.
(here you can see a photo from prototype: http://tzitzikas.webs.com/linear_first.jpg )
Also, the other problem is that the T3 transformer and the resistors R9,R10,R11,R8 and the r.f choke VK200 are very warm when the linear operates.
But the basic problem is to increase the output power.
The mosfets are from Siliconix but i have ordered and i will try to use International Rectifier's IRFP360 mosfets.
Do you have any idea what is the problem for the low output power? Do you have to propose any change to broadband transformers to increase the output power? I tried to change the value of C4=3,9nf capacitor but the output power was more low.
Thank you.
bertus
Joined Apr 5, 2008
22,988
Are the mentioned resistors induction free?
The VK200 inductor is rated for 3 A continuos and 5 A peak.
Bertus
tzitzikas
Joined Jun 3, 2007
41
hi. all the resistors are carbon.
Could i increase the output transformer T1 number of turns, but keep the ratio 1:2 constant, to increase the output power? It will help? (4 turns primary and 8 turns secondary or 5 turns primary and 10 turns secondary)
Or to increase the secondary number of turns of T3 (with 25ohm coaxial cable)?
If i use bigger ferrite beads?
tzitzikas
Joined Jun 3, 2007
41
ok
ifixit :
about choke vk200: i am thinking to change the vk200 with a ferrite bead FB-43-7351 (i have many of them) . how many turns i must use to have the same inductance with the vk200?
If i use 4 vk200 (in parallel ) i will use the same inductance or 1/4 inductance, It will work?
bertus
Joined Apr 5, 2008
22,988
The picture does not tell me anything about the core material.
In the table you can see there are different types of W core material used.
Bertus
ifixit
Joined Nov 20, 2008
652
If the problem of low power is with the T1 transformer not having enough inductance, then adding more turns could help get more power. If the problem is core saturating, then using a larger core could help.
It is difficult for me to trouble shoot from here.
Please Note: I will be off-line until June 6th. Vacation time.
Regards,
Ifixit.
tzitzikas
Joined Jun 3, 2007
41
i am thinking to change the ferrite beads with bigger to reduce the losses and to increase the number of turns at T1 and T3 transformers but i will keep the ratio constant.
I am thinking at T3, to put 2 turns primary and 10 turns secondary (coil with 25ohm coaxial cable) and at T1 to put 4 turns primary and 8 turns secondary or 5 turns primary and 10 turns secondary. What do you think? These changes will help to increase the output power?
