hello guys
im doing a project and i need to amplify a bipolar signal!
as i know the amplifier shoud be supplied with Vcc+ & Vcc- in order to amplifiy the both side of the bipolar signal!
my question here is how can i have a ground and Vcc- at the same time!? im using a battery as my supply voltage and if i assume Vcc- as my ground then the negative signal will be cut!
i want to construct the circuit on breadboard but i still couldn't amplify the signal so far!
i tried to make a line as my ground insted of Vcc- line but i still couldn't !!
can anyone tell me the correct way to do it?
thank you
