In the absence of you saying what you are measuring and the inaccuracies as you see them , it would be guessing what is wrong. For example if you are measuring high ohms resistance, say megohms- and you have your fingers acroos trhe meter leads tips , hence across the resistor, the reading would be lower. If you are measuring very low ohms say one ohm- the reading would show high, due to the resistance of the meter leads which should be substracted. So if you can fill in some detail, it should help clarify.how cum my multimeter dosn't measure accuratley with resistors
by Jake Hertz
by Duane Benson
