Smoothing capacitors
floomdoggle
Joined Sep 1, 2008
217
Hi all,
I am making windmill generators. With the AC generators, after the bridge rectifier, is there a formula, or rule of thumb, on the size of the smoothing capacitor? I am using anywhere from 1.5 volts to 48 volts. I have lots of recovered capacitors from old vcrs and betamaxes. And 1 or more?
Dan
Metalfan1185
Joined Sep 12, 2008
185
There may be, if there is i dont know what it is...
Iwould try a few different values in paralell and use an oscilloscope to display the ripple, and then add/remove caps until you are rid of the ripple the best you can.
Audioguru
Joined Dec 20, 2007
11,248
For a 60Hz mains frequency and a full-wave rectifier bridge I use a graph that shows the peak-to-peak voltage of the ripple at various currents with various capacitor values. There is a formula on the graph for you to convert to a 50Hz mains frequency.
SgtWookie
Joined Jul 17, 2007
22,230
Hi all,
Dan
Dan,
Those old caps, if electrolytic, are more than likely no good anymore. They're electrolytic. Electrolytic caps can sometimes be re-conditioned over several days using current limiting resistors, but the process is tedious at best. Electrolytic caps should be derated (rule of thumb) by 50% of their voltage rating; eg: if a cap is rated at 20v, it should not be used in a circuit that may have more than 10v on it.
If you want to try to recondition some of your salvaged caps, try charging them using a 20k-30k resistor to their rated voltage, over a period of time.
Salvaged capacitors aren't a good choice for storing energy, IMHO. Batteries are far better. Lead-acid are expensive. Nickle-iron batteries were widely used in the 1930's-1940's, and were quite inexpensive - although they didn't retain a charge like the lead-acid batteries did. Still, the nickle-iron batteries had an extremely long life cycle by comparison.
Wendy
Joined Mar 24, 2008
23,809
Interesting chart, been looking for something like that myself. What is the source, if I might ask?
floomdoggle
Joined Sep 1, 2008
217
Thanks for the responses. Sarge, the caps will be used to smooth rectified AC, will they work for that?
Audioguru, I don't understand how the chart works. I'll be using 200rpm as my full charging speed.
Dan
