My old data book collection
RichardO
Joined May 4, 2013
2,270
I have done an inventory of my collection of old data books. It numbers about 600 books at this time. There are still some stragglers that need to be added when I get the time.
See this thread for background:
http://forum.allaboutcircuits.com/t...onductor-linear-applications-handbook.100301/
Since this is the Electronics Resource Forum I am going to make an offer to members of the AAC Forums. I am willing to scan a limited number of obscure data sheets (not entire data books) from my collection. All I ask is that you do not request data sheets that are already available on-line.
-- RichardO
35,249
I am requesting your permission to post your list on this forum rather than as an attachment.
It may prove handy to someone one day.
Lestraveled
Joined May 19, 2014
1,946
You are a very kind and generous person for offering this. More than once I have had the need for a data sheet that is no longer available. Just because a part is 20 years old (or more) does not make it irrelevant.
Thank you Richard
35,249
May I offer one more suggestion. When you scan the requested data sheet, can you please send me the pdf file so that it can be archived and hosted on the AAC server? We will have to check with jrap about copyright issues on copying data sheets.
Lestraveled
Joined May 19, 2014
1,946
Wow, a 1952 ARRL hand book. (I was born a year later.) I thought I was doing good with my 1963 ARRL handbook.
Again, Richard, Thank you.
RichardO
Joined May 4, 2013
2,270
The handbook was a recent find. (I'm only a smidgen older than the book.) At the same time I got the ARRL handbook, I also found a 1954 (I think) TV Video handbook. As you can see, I am still catching up on my studies. :D
Thanks to J. B. Saunders!
Saunders is a new and used electronic parts supply store in Boulder, Colorado. They are kind enough to give away old data and technical books like this ARRL handbook. :):)
RichardO
Joined May 4, 2013
2,270
To seed the process I will start with 2 unusual data sheets.
The first one is a very early data sheet for a PIC microcontroller. Note what PIC stands for!
Next is a data sheet for what was, for a while, what I would consider the closest to a "ideal" op-amp. I especially like the application example for a high power audio amplifier.
atferrari
Joined Jan 6, 2004
5,031
Looking for the AN012 (It could be, maybe, AN12) explaining the internals of the ICL8038 or equivalent.
I do not know if it actually exists but in all versions of the AN013 (related to the 8038), it is mentioned.
Intersil, and IIRC Maxim. I know there are more.
Gracias for any help.
atferrari
Joined Jan 6, 2004
5,031
I think I have a description of XR8038 somewhere.
Gracias for replying, Señor Chip.
The description is in the datasheet already.
What I am looking for is the elusive "AN012" specifically mentioned in the AN013.
Maybe it was never released or the AN012 is just the datasheet where the circuit is (summarily) explained.
Thanks again.
atferrari
Joined Jan 6, 2004
5,031
Gracias Bertus.
I got that one already. Question No. 11 is where AN012 is mentioned. It seems that I will not find it but I can live with that anyway. :( ;)
Thanks again and Happy New Year.
bertus
Joined Apr 5, 2008
23,014
Even when you go to the intersil site and search for the AN012, the AN013 pops up.
No AN012 to find.
Bertus
RichardO
Joined May 4, 2013
2,270
I suspect that the reference to AN12 is not correct but I will check for it in my old data books and spec sheets.
I have attached my LTspice simulation of the ICL8038. This is the circuit right out of the data sheet. Maybe the simulation can help answer some of your questions.
atferrari
Joined Jan 6, 2004
5,031
A google search will show the same sentences including "AN012" all coming from inside AN013.
THANKS for the model. :) How long it took you to assemble that?! :eek:
sheldons
Joined Oct 26, 2011
613
If there are any interesting audio/preamplifier type schematics in your arrl books or tx schematics they would be of interest. ....
