this is a crude schematic of a 16 bit carry select adder that I designed.The problem is what type of multiplexer should i used, because the output of multiplexer is 1 only, the reference book I had been give said it should out have 5 outputs.
is it possible that adder can be modified to become multiplexer?
Comment on my adder design, if u have any opinion thanks.
