| General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos. |
Thread Tools | Display Modes |
#1
Please guys, i need u to assist me get a detailed circuit diagram on an automatic voltage regulator (1kva). I need it a for a project work. Well, i will appreciate if u can email it to me on - preyeeteimo23@yahoo.com.
Thanks, Harry Last edited by preye2007; 12-27-2007 at 04:15 PM. Reason: a slight mistake |
#2
Wow.
A 1000 volt-amp regulator, no more specifics, and you want the result E-mailed to you? ![]() Good luck with that. |
#3
Quote:
Thank you. Dave
__________________
"If I have seen further, it is by standing on the shoulders of giants" - Sir Isaac Newton All About Circuits
#4
Quote:
First, you have specified an infinite number of possibilities and simultaneously asked for a detailed solution. Can you see any potential problem, there?? If you don't yet understand what needs to be specified, before designing or selecting a regulator, you can ask, here, and someone will probably be glad to help you. Second, you asked for the solution to be emailed to you. That type of request is generally considered to be a faux pas, in bad form, a breach of proper etiquette, ill-mannered, etc, on discussion forums, in general. Not only would it selfishly defeat one of the main purposes (and beauties) of the discussion-forum format, which is to share information and solution-development processes with everyone and amass a knowledge-base, it also gives at least the appearance of being rudely presumptuous. At least you did say "Please", though. Last edited by gootee; 12-29-2007 at 09:55 PM. |
| Bookmarks |
| Tags |
| automatic, regulator, voltage |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| solid state voltage regulator | Unregistered | Feedback and Suggestions | 0 | 11-07-2007 03:23 PM |
| Switching regulator (boost) voltage ripple | Tyco | The Projects Forum | 4 | 03-21-2007 04:31 PM |
| Voltage Regulator Tester VRC101-B | mejdi_electronique | General Electronics Chat | 3 | 03-07-2007 12:17 PM |
| voltage regulator bypass | max2 | The Projects Forum | 3 | 07-26-2006 09:28 AM |
| voltage regulator | isha | General Electronics Chat | 5 | 11-02-2005 09:51 AM |
