All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Closed Thread   Post New Thread
Thread Tools Display Modes
  #1
Old 10-27-2007, 08:48 PM
denman_100 denman_100 is offline
Junior Member
Default Coupling to a power line
I am working on a project and I was trying to find some information regarding how to power devices inductively off of a power line. The lines will be 100A +- 50A and anywhere between 4kV to 12kV. What I am building will be clamped around the line. I am looking to make a 9VDC power supply to power a device and also to charge a battery.
I was able to find this post regarding a similar idea. http://forum.allaboutcircuits.com/showthread.php?t=2688
My first thoughts were to use some coils placed near the line to induce some voltage a la Faraday's law. However, a lot of turns were required to do that. I am now considering using a CT like device around it.
I am just looking for some insight into this. A CT has a burden or some type of load across it, never open circuited so to prevent huge voltage differences. I guess what I'm wondering is how to get the voltage I want out of the secondary. A 100:5 CT will give me 5A at normal current, is this regardless of the line voltage? If I put the same CT on a line with half as much voltage, will it still deliver 5A on the secondary with a 100A primary?
The reason I ask is because the power transfer doesn't quite make sense to me. 12kV 100A primary put through a 100:5 CT with a 1 ohm load will have 5A and 10V across the secondary. Why is the voltage not 240kV as expected from a 100:5 ratio? This seems to ignore power transfer equation for transformers. Am I to model the secondary as a perfect dependent current source?
In reference to the link I posted, the poster mentioned putting a diode bridge with cap and zener to create his power supply. My only question is how would he determine the voltage input to the bridge? If he needed a 3VDC output, he'd need around 5-6 VAC peak to generate it. If the power supply is to load the secondary windings, I don't see how to set an input voltage.
Sorry about the long post, but thanks in advance to everyone.
  #2
Old 10-27-2007, 08:56 PM
beenthere's Avatar
beenthere beenthere is offline
Super Moderator
Default
In order to be able to get useful power from inductance, very close-coupling is needed. I believe the effect is used to recharge batteries in electric toothbrushes.
The field around a single conductor is not dense enough to get power from it. That is why transformers use many turns and a flux-coupling core to be efficient.
You probably know most of this, but here is apointer to the Wikipedia article on CT's - http://en.wikipedia.org/wiki/Current_transformer.
  #3
Old 10-27-2007, 09:05 PM
Junior Member
Default
Thanks for the reply. If I attach the CT around the wire, I'm assuming that the coupling will be much greater. Even with better coupling though, the questions at the bottom of my first post still apply. If I connect a rectifier bridge, cap and LM317 regulator to the secondary of the CT, what will it rectify? IE: If it is a 100:5 CT and 100A is on the primary, will it be rectifying :V = 5A * load impedance of my circuit?
Beenthere: I think the CT will will help with coupling, if not, please tell me
  #4
Old 10-28-2007, 11:45 PM
beenthere's Avatar
Super Moderator
Default
You're missing the point of a current transformer. It exists to provide an analog of the main power line condirions so those conditions may be safely monitored. It is not a device that may be used to produce power.
  #5
Old 11-02-2009, 10:32 PM
plcresearch plcresearch is offline
Default
contact me
<snip>
i would be happy to help you!!!
Last edited by beenthere; 11-02-2009 at 11:53 PM. Reason: email removed by moderator
  #6
Old 11-02-2009, 10:39 PM
BMorse's Avatar
BMorse BMorse is offline
Default
Quote:
Originally Posted by plcresearch View Post
contact me
<snip>
If you are going to offer help, you need to post it here so others looking for similar info can have access to it if needed..... that is the whole point of these forums.....
__________________
There is no spoon -Neo-
Disclaimer: The example programs,circuits, projects and information I provide or post on this web site are for educational purposes only. By copying anything from this site posted by me, you agree to the "as is" nature of the programs, circuits, information and to the statements listed in this disclaimer.No warranty or liability is expressed or implied. Working with AC /DC voltages can be dangerous and even deadly. Proceed at your own risk!
  #7
Old 11-02-2009, 11:55 PM
GetDeviceInfo GetDeviceInfo is offline
Default
and to warn one of impending death.
  #8
Old 11-03-2009, 01:15 AM
CDRIVE's Avatar
CDRIVE CDRIVE is offline
Default
Quote:
You took the words right out of my mouth.
__________________
__________________________________________________ ___________________________
Disclaimer: Any information that I post is intended for educational purposes only. No warranty or liability is expressed or implied. Note: Working with household line voltages (Mains) can be dangerous. Proceed at your own risk!
  #9
Old 11-03-2009, 01:24 AM
beenthere's Avatar
Super Moderator
Default
This is a very old topic that got revived somehow.
__________________
First comes the hardware, then the software.
Bookmarks
Tags
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Helicopter power transmission line repair RichG General Electronics Chat 22 06-03-2009 07:46 PM
power line communication vineethbs General Electronics Chat 28 03-03-2008 02:02 PM
Current measuremnet on power line 95se5m The Projects Forum 1 10-11-2007 01:46 PM
DC Power Delay - 5 seconds ON and 190 seconds OFF | HELP we87 General Electronics Chat 9 09-28-2006 06:23 AM
X10 power line modem tyambty General Electronics Chat 0 05-18-2005 06:49 AM
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License. Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
