All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Electronics Resources
Notices
Electronics Resources Get help with all types of electronics resources, including books, websites, datasheets, technical literature, and software.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 07-15-2007, 11:04 PM
kender kender is offline
Location: SF Bay Peninsula, California, Planet Earth, Solar System, Milky Way
Send a message via MSN to kender Send a message via Yahoo to kender
Default DRC tutorial for OrCAD Layout 9.2
Folks,
Iíve finished a layout in OrCAD 9.2 Layout Plus, and I want to run DRC on it. Itís a simple board with only 45 nets, but Iím getting few hundred DRC errors. I guess, Iím getting these errors, because I havenít set up the rules and parameters correctly.
Would somebody be so kind and give a link to (or upload) a tutorial for OrCAD Layout DRC ?
Some of my particular question about DRC:
- Can I get a text report with warnings and errors?
- How can I change the DRC parameters such as trace and gap widths?
- How can I change severity levels Ė whether a certain type of discrepancy generates an error or a warning?
Iíve checked the tutorial in the Help menu, but thereís very little information about DRC.
Thanks,
Nick
__________________
Read the label, before opening a can of worms.
  #2
Old 09-28-2007, 08:00 PM
cooloo cooloo is offline
Default
Something's wrong with your setup . Usually , you can go to Layout help on help menu ( or hit F1 ) .
I would check the loading files first . Template , strategy ... . Try to load it with default .
Read the errors and try to figure out from which part of layout that causes it happen . Good luck .
ps : my trick is sometime I go back to the board that I designed before ( without errors ) and compare it with the new one .
Tags
Related Site Pages
Section Title
Worksheet Boolean algebra
Worksheet High-reliability circuits
Worksheet Flip-flop circuits
Textbook Credits : Contributor List
Worksheet JFET amplifiers
Worksheet Junction field-effect transistors
Textbook Circuit components : Using The spice Circuit Simulation Program
Textbook SPICE models : Diodes And Rectifiers
Textbook Semiconductor devices in SPICE : Solid-state Device Theory
Similar Threads
Thread Thread Starter Forum Replies Last Post
Cheap PCB Layout Design Services [price updated] donpetru The Flea Market 1 08-04-2014 05:55 PM
orcad 9.2 layout library for sodimm(DDR2) 200 pin connector dhivitha Electronics Resources 0 05-02-2011 01:20 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
