How to solder with prototyping board?
Peter Pan
Joined Mar 24, 2005
122
Hello
I 've got used to PCB but this time I need to solder using prototyping board. it has a contact per hole as shown on the pic attached and my question is: how to connect contacts - whether I should solder wire links between contacts required or solder contacts together into traces to connect them on board?:confused: what is normal practice in the case?
hgmjr
Joined Jan 28, 2005
9,027
There no set standard technique used to interconnect the components. It is more or less left up to individual preference. As for myself, I solder the component or in the case of an IC, a socket onto the board.
I would recommend you do a paper layout of the circuit using paper that has a grid on it. This approach gives you a chance to test your layout and work out how you will distribute the power supply voltages to the components.
hgmjr
bloguetronica
Joined Apr 27, 2007
1,544
That kind of board that you have there is used for wire wrapping, a solderless technique. I think that is the wrong type of board for your project. I would advice for the use of a stripboard or tripad board (the last is better for IC's). You will have to exercise your google finger (as someone said before).
hgmjr
Joined Jan 28, 2005
9,027
That kind of board that you have there is used for wire wrapping, a solderless technique....
Indeed the prototype board pictured in the OP's initial posting is well suited to wire wrap but I have had good success using it for various projects in which I have soldered components along with the numerous point-to-point interconnecting wires.
hgmjr
mrmeval
Joined Jun 30, 2006
833
I have one that looks similar. Unless it's a plated through hole it's not good for wire wrap.
Mine has pads on one side around the holes but no plate through. Use whatever hookup method makes you giggle that's technically correct. I've used the component leads, scrap wire, cut off component leads, pulled the stranded wire from old AC cords and separated the strands and several other types of wire. You can tack solder them on, run multiple wires in a hole. build teepee's of your diodes and resistors, etc.
Now if your circuit is beyond a basic low speed analog or digital you'll not easily get away with that.
As stated it's a real pain if you're using ICs unless it's a few pins and a very simple circuit. Those however are more expensive.
hgmjr
Joined Jan 28, 2005
9,027
mrmeval raise a good point about the type of circuitry for which the prototype board will be used.
As with any pc board design, high frequency signals above a few megahertz will require additional care when it comes to your component layout. The board you have chosen has no ground plane to minimize the likelihood of high frequency coupling into adjacent circuits.
It would be advisable to make liberal use of 0.1 uFd or 0.01 uFd decoupling capacitors very close to the IC used in your design.
hgmjr
bloguetronica
Joined Apr 27, 2007
1,544
I don't think a stripboads would be more expensive than the board shown. A tripad board, maybe. A tripad board is really handy for projects with ICs, but for your project a stripboard will do.
hgmjr
Joined Jan 28, 2005
9,027
Here is an example Stripboard photo . Stripboard gets its name from fact that the copper is etched to form strips along the length of the board. Like the board pictured in the OP's original posting the holes are on a 0.1 inch by 0.1 inch grid. Other grid spacings are available in many cases. This type of board requires that cuts be made at various points along the strip to break the conductor path up to form the required conductor paths. A DIP (dual-in-line) IC package also requires the careful cutting of the strip as selected the IC site so that the appropriate pins are electrically isolated from each other. This strip format facilitates the bussing of power and ground. A handheld Dremel tool is my tool of choice when using this type of prototype board.
hgmjr
