Simulating a Hall effect throttle in Multisim
bytraper
Joined Sep 28, 2010
127
Hi everyone!
I'm trying to work out how to simulate a hall effect throttle in multisim, but so far haven't had much luck.
Anybody have any ideas how I can achieve this?
38,537
What are the characteristics of the hall effect throttle that you are trying to simulate? Is it a variable output voltage or a variable resistance?
bytraper
Joined Sep 28, 2010
127
Variable output voltage, from 0.75 at zero position and 3.75 at full position.
I tried using a voltage regulator, but that didn't work too well.
SgtWookie
Joined Jul 17, 2007
22,230
Why don't you simply use a voltage source, with a pulse output, starting voltage 0.75v, end 3.75, with a rise time of whatever you need?
