JK Flip-Flop binary counter using 555 as clock
CaptainPrice
Joined Aug 12, 2009
49
Im trying to make a binary counter. "ripple through" counter
I'm using a 555 chip to make a square wave. however when the output of the 555 is fed to the first Flip-Flop it doesnt appear to do anything. [ as opposed to when i manually touch the F-F to GND]
I'm using SN54LS73A JK master slave flip-flop. its negative edge triggered.
I want to use 3 bits so it cycles between 0to7 on the output.
Right now, I have all J&Ks connects to positive. and Q feeding clk2 and q2 feeding clk3. LED outputs are q1,q2,q3 correct?
The output right now appears random, but does cycle a bit(not completely in binary order) when i manually use a wire to momentary put clk1 to ground.
Any idea how i can get this thing working right?
Datasheets
http://www.datasheetcatalog.org/datasheets/208/338045_DS.pdf
http://www.taydaelectronics.com/datasheets/A-032.pdf
555 connected like so
http://www.ohmslawcalculator.com/555_astable.php
R1=1k
R2=12k
C=220uf
Trying to connect flip flops like this
http://www.wisc-online.com/objects/ViewObject.aspx?ID=DIG4203
#12
Joined Nov 30, 2010
18,224
You did an excellent job of showing us the instructions, and they are good. You must show what you did for us to find the mistake. Got camera?
Wendy
Joined Mar 24, 2008
23,797
Make the 555 go slow, say 1 hz or less. You can use a simple probe using something like this to see what the logic is doing...
Be sure all the inputs are connected to the correct logic levels, don't leave them floating. You will note the worksheet you are referencing to shows them at a logic 1. Be sure all the inputs are covered, such as set and reset.
CaptainPrice
Joined Aug 12, 2009
49
Haha!!
I had left the Clear pins floating, I connected them to Positive, and now it works!!
now to go make it more complicated....
