All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 09-29-2011, 07:40 PM
crazybuoy crazybuoy is offline
Junior Member
Default Simple solar tracker with stepper motor
There is a attached circuit to make run stepper motor continuously. 2 LDRs can be replaced with Forwd and Back-Wrd switches by separating then with a paper card. But where to fix another LDR to disable the circuit when sun hides?
Thanks in advance.
  #2
Old 09-29-2011, 11:05 PM
Bernard's Avatar
Bernard Bernard is online now
Default
That is one wierd circuit- or maybe I've lost a few more marbles. If you have two LDR's, then you can tell if it is dark.
  #3
Old 09-30-2011, 05:35 AM
vrainom vrainom is offline
Member
Default
Fun fact: It seems the te555-1 is a rebranded pic 12f629. That explains the 7805 regulator.
Unfortunately you can't just replace the switches with ldr's because they're not switches, they're light dependent variable resistors. I'm not saying it can't be done, it's just more complex than that.
case in point:
  #4
Old 09-30-2011, 03:54 PM
Bernard's Avatar
Default
Thanks vrainom, I had no luck in researching the chip.
  #5
Old 09-30-2011, 06:51 PM
BMorse's Avatar
BMorse BMorse is offline
Default
it also looks like they are multiplexing 2 of the stepper outputs as the switch inputs in the stepper motor controller circuit, so, just replacing them with an LDR could really cause some issues with the step logic of the motor... what you would need is an entirely different circuit that can "emulate" the switch press, you can use a comparator circuit with the LDR's and just have the comparator close some small SPST relays.... that way you can also build in some hysteresis or have a "window" into the circuit to where if either LDR has any light, then the comparator just doesn't do anything....
__________________
There is no spoon -Neo-
Disclaimer: The example programs,circuits, projects and information I provide or post on this web site are for educational purposes only. By copying anything from this site posted by me, you agree to the "as is" nature of the programs, circuits, information and to the statements listed in this disclaimer.No warranty or liability is expressed or implied. Working with AC /DC voltages can be dangerous and even deadly. Proceed at your own risk!
  #6
Old 09-30-2011, 10:40 PM
Bernard's Avatar
Default
A speculative outline: Sample LDR " JEM Cell " , 1k to +5 V & cell, other cell lead to gnd. No cover- .64V; one semi transparent cover-1.27V;2 covers-2.0V; dark-3. V, [ cell Vs]. U1, C, comparator gives direction; U2, I, invertor. U3 & U4, with U5, gives a drive signal if cells are suficently unbalanced, if low = stop. U8 detects darkness. Looks like we need another IC to make sure that both cells are high. The idea is that if the cells are ballanced and are illuminated, motor is off. If cells are un ballanced & illuminated, then either A or B will be high, motor will run. If cells are both dark- motor off. Pos input to U5 is about 1/2V.
  #7
Old 10-01-2011, 01:19 AM
Bernard's Avatar
Default
Added U9, now if both cells are dark, the motor will be off.
Tags
Related Site Pages
Section Title
Worksheet Design Project: Stepper motor driver
Worksheet Stepper motors
Worksheet Open-loop opamp circuits
Textbook Stepper motors : Ac Motors
Textbook Reluctance motor : Ac Motors
Textbook Special-purpose diodes : Diodes And Rectifiers
Similar Threads
Thread Thread Starter Forum Replies Last Post
Help on c programming, using PIC16F648A to control a RS stepper motor icem Programmer's Corner 3 02-28-2012 07:22 PM
K179 unipolar stepper motor kit mrel The Projects Forum 8 09-30-2011 10:18 PM
Help with solar tracker electronicsnewbie The Projects Forum 7 01-18-2010 02:48 PM
How to put load or termination of stepper driver leads (if motor not connected) Carbon Amped The Projects Forum 14 01-14-2010 10:12 PM
Problem with stepper motor functioning thavamaran The Projects Forum 10 03-31-2009 07:48 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
