| The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it. |
Thread Tools | Display Modes |
#1
Dear friends |
#2
Your DC relay may have a diode across its' coil. That would short out the transformers' output for 1/2 of the cycle.
You can get a small full-wave bridge rectifier from your local Radio Shack store for around $1.39+tax. http://www.radioshack.com/product/in...ductId=2062581 It has four leads; two are AC (indicated by ~) and the other two leads are DC, marked + and -. You just connect it up. If the relay still buzzes, you may need to add a filter capacitor across the bridge output. This would probably do the trick: http://www.radioshack.com/product/in...tic+capacitors
__________________
General info: If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input. |
#3
You can follow this attachment.......
I think you will be very much clear...... |
| Tags |
| 12vac, 12vdc |
Related Site Pages
| Section | Title | |||
| Worksheet | Electromechanical relay logic | |||
| Worksheet | Basic AC-DC power supplies | |||
| Worksheet | Advanced electromagnetism and electromagnetic induction | |||
| Textbook | Special transformers and applications : Transformers | |||
| Textbook | Pulse Width Modulation : Dc Motor Drives | |||
| Worksheet | Kirchhoff's Laws | |||
| Textbook | Vacuum tube audio amplifier : Discrete Semiconductor Circuits | |||
| Textbook | Sensitive audio detector : Ac Circuits | |||
| Textbook | Rectifier circuits : Diodes And Rectifiers | |||
| Textbook | Sensitive voltage detector : Dc Circuits | |||
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 12vdc vs. 12vac | Lightfire | General Electronics Chat | 5 | 05-07-2011 02:40 PM |
| 9vdc boost to 12vdc | NT15MCP | The Projects Forum | 4 | 07-27-2010 11:55 AM |
| 12VAC common to 12VDC floating | Kelly Lee | The Projects Forum | 2 | 08-25-2009 04:31 PM |
| 12vdc stability problem | gribbler | The Projects Forum | 11 | 06-09-2009 11:24 PM |
| 7805 & 12VDC Power Supply Problem | JDC | The Projects Forum | 10 | 10-24-2008 06:09 AM |
| Thread Tools | |
| Display Modes | |
