good day to all,
can someone help me on my project VAC to VDC,,i had a motorcycle with a 12VAC up to 14VAC to headlight at high reving with a 2.8amp charging on my battery using clamp tester,,sory guys im a newbie and not familiar to converting VAC to VDC,,some other say a simple rectifier and capacitor will do..but im not with that and not tested it,
im going to put an HID on my motorcycle(MC) but the charging V is up to 14VDC with a 2.8amps..my ballast nid a 9-15VDC and 3.3amps in normal..i can put my HID wiring straight to the battery but after an hour my battery get drain,,so can anyone help me how to make a 12VAC to atleast 12VDC 3.3amp.thanks
