All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Closed Thread   Post New Thread
Thread Tools Display Modes
  #1
Old 03-25-2007, 04:42 PM
allied allied is offline
Junior Member
Default How to check a CAPACITOR
How to check a capacitor if its defective or not using analog and digital multimeter?
Thanks.....
Allied
  #2
Old 03-25-2007, 05:21 PM
beenthere's Avatar
beenthere beenthere is offline
Super Moderator
Default
If it's not electrolytic and you can't meter it, then you might as well taste it.
Defective electolytics usually show signs, like blown-out vent plugs, or having grown noticablly taller than the label.
Why do you need to be able to check caps without test equipment?
  #3
Old 03-25-2007, 06:02 PM
Dave_ Dave_ is offline
Junior Member
Default
Wow, I've never really thought about that until now. I don't think it's possible to use a multimeter. The first way that comes to my mind is put it into a RC network, and calculate how long after charging fully it should discharge to 37% of its final value.
  #4
Old 03-25-2007, 07:43 PM
beenthere's Avatar
Super Moderator
Default
Imagine if the value is 15 pF? And how do you track the voltage down to 37% without a meter?
  #5
Old 03-25-2007, 08:30 PM
VincinChristmas@hotmail.com VincinChristmas@hotmail.com is offline
Junior Member
Default
You can use your multimeter as an ohmmeter to test the capacitor.
1) Discharge the capacitor by shortening its leads. That is - use a wire and connect the leads of the capacitor together. This will discharge it.
2) put your multimeter in the high ranges 10K-1M
3)CONNECT MULTIMETER TO CAPACITOR LEADS(OBSERVE THE POLARITY IF ELECTROLYTIC). AT SOON AS THE LEADS MAKE CONTACT, THE METER WILL SWING NEAR ZERO. IT WILL THEN MOVE SLOWLY TOWARD INFINITY. FINALLY THE METER WOULD COME TO BE INFINITE OHMS BECAUSE THE CAPACITOR IS BEING CHARGED BY THE BATTERY OF THE MULTIMETER.
4) IF THE CAPACITOR IS BAD, IT WILL GO TO ZERO OHMS AND REMAIN THERE. THIS IS CALLED A SHORTENED CAPACITOR
5) IN THE CASE OF AN OPEN CAPACITOR THERE WILL BE NO OHMMETER INDICATION.
6)SOME CAPACITORS HAVE A LOW DIELECTRIC LEAKAGE. YOU WILL KNOW THIS IF THE OHMMETER COMES TO REST AT A POINT LOWER THAN INFINITE. TEST A KNOWN GOOD CAPACITOR OF THE SAME TYPE TO BE SURE
  #6
Old 03-26-2007, 04:11 AM
thingmaker3's Avatar
thingmaker3 thingmaker3 is offline
Super Moderator
Default
Vincin's method will work with sufficiently large capacitor values. (Especially if one uses an analog meter.) Tiny capacitors can only be checked with a capacitance meter, or by using them in an AC circuit and checking for variation from calculated voltage drop.
__________________
"I want to establish in your mind very clearly that you must not think I deny all that I do not admit. On the contrary, I think there are many things which may be true, and which I shall receive as such hereafter, though I do not as yet receive them; but that is not because there is any proof to the contrary, but that the proof in the affirmative is not yet sufficient for me"
- Michael Faraday
  #7
Old 03-26-2007, 04:18 AM
Tube Tech Tube Tech is offline
Junior Member
Default
Adding to what Vincin said: Reverse the leads and look for a major kick in the needle. If the cap charged from the DC voltage induced by the meter, the cap will discharge when the leads are reversed, causing a twitch in the needle.
  #8
Old 03-27-2007, 08:48 AM
goodbyegti goodbyegti is offline
Member
Default
How about an ESR meter?
  #9
Old 03-28-2007, 05:58 PM
alim alim is offline
Member
Default
To effectively test acapacitor one should use capacitance meter -one that reads in uF nF pF, an ESR meter is very useful for checking electrolytics in circuit, they are cases where the uF was good on acapacitance meter but cap had high ESR as shown on an ESR one. The point is one meter may not adequately serve all your needs.
  #10
Old 12-05-2009, 08:48 AM
loosewire loosewire is offline
Default
Sign up and we can give you more Info on testing caps.
Bookmarks
Tags
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Equivalent impedance and reactance of a capacitor xMrdibbsx Homework Help 5 12-04-2007 06:20 PM
The capacitor Filter + RC circuit time constant Dave_ General Electronics Chat 8 03-28-2007 10:06 AM
Starter Capacitor Iodem_Asakura General Electronics Chat 1 01-27-2006 01:32 AM
how to check pnp transister whith analog or digita newone General Electronics Chat 3 01-06-2006 01:55 PM
How does the signal go through a capacitor nubi78 General Electronics Chat 3 12-05-2004 03:36 AM
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License. Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
