That is correct.SgtWookie,
I'm not sure what I'm looking at in the drawing.
My fan capacitor has two wires coming out of it.
I can see that V1 is 10 volts positive, coming in to the resistor, and then the resistor hooks up to one wire of the capacitor. I'm guessing the 10 volts negative of the power supply then hooks into the other wire of the capacitor?
It's OK if you don't use a switch. It might be easier if you did.I don't have a switch, should I add one into my circuit?
by Duane Benson
by Duane Benson
by Jake Hertz
by Duane Benson
