All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 04-02-2011, 11:14 AM
QuangVuong QuangVuong is offline
Junior Member
Default Game Buzzer Circuit
Hi
I'm kinda new to making circuits. I have a monostable 555 timer circuit which I need to integrate with another one. So if S1(PTM) is pressed thelight will stay on for about 5 seconds and the other switch cannot be used when the other switch is on. Vice versa.
So I have drawn up a circuit in Yenka, and everything works. Except the light stays on forever. I tried increasing the resistance and lowering the capacitance but the light will not turn off after a few seconds. Would anyone have an idea? To turn the light off after a few seconds. If anyone wants to have a look at the circuit, I'll upload it.
Its the bottom circuit.
  #2
Old 04-02-2011, 11:16 AM
Bill_Marsden's Avatar
Bill_Marsden Bill_Marsden is offline
Super Moderator
Default
Schematic please. Schematics tell much more than words.
Have you thought of using the output of each 555 to feed the reset line of the others?
__________________
"Good enough is enemy of the best." An old engineering saying, Author unknown.
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input. Thanks for the verbage Wookie.
  #3
Old 04-02-2011, 11:23 AM
Junior Member
Default
Uploaded first post.
  #4
Old 04-02-2011, 12:00 PM
KMoffett KMoffett is offline
Default
Never seen YENKA. Please post your image in a .png, .jpg, .gif, .pdf, or .doc file format so we can see it.
Ken
__________________
"To invent, you need a good imagination and a pile of junk."
Thomas A. Edison (1847 - 1931)
  #5
Old 04-02-2011, 12:48 PM
Super Moderator
Default
I was about to make the same comment. I haven't even heard of it, which is unusual. The best graphic format is .png, or .gif .
__________________
General info:
  #6
Old 04-02-2011, 10:10 PM
Junior Member
Default
Yenka is a program which helps us draw up circuit diagrams and test them. It's a free program.
Anyway, I'll take a screenshot and upload it here.
  #7
Old 04-03-2011, 01:34 AM
Junior Member
Default
  #8
Old 04-03-2011, 02:46 AM
Super Moderator
Default
Try this, it is what I suggested earlier...
__________________
General info:
  #9
Old 04-03-2011, 02:52 AM
Junior Member
Default
Which inverter should I be using? 324op amp or 741 op amp?
I need to use the basic monostable design to make a buzzer system, where a light turns on when one of the PTM switches are pressed. The light will turn off shortly. Anyone can press their switch, but only one light can stay on at a time. There will only be two switches.
Im also thinking of using a thyristor, but then I need to find a way to connect the monostable circuit to a thyristor and then have two connected together. I can do it with a LED, but am having trouble with connecting the monostable circuit to the thyristor. Does anyone have an idea?
Or how to just make a circuit which works like game shows on TV, but it has to use a monostable design?
  #10
Old 04-04-2011, 07:22 PM
Super Moderator
Default
How about a CMOS (digital logic) inverter? You can also use 2 resistors and a transistor to make a single inverter (any general purpose NPN and two 10KΩ resistors).
You didn't name inverters, you named op amps.
Classic CMOS Hex inverters (6 in a package) would include a 4049, 4069, 40098, 40106. TTL is limited in voltage but examples would be the 7404, 7414.
A good chip reference (there are many) is Sams Electronics Circuits (no relation to Sams).
http://users.otenet.gr/~athsam/database.htm
With any chip, be it digital or analog, ground the inputs to unused gates or op amps.
__________________
General info:
Tags
Similar Threads
Thread Thread Starter Forum Replies Last Post
not worthy electrical engineering student (simple game circuit using decade decoders) raim013 The Projects Forum 15 12-15-2010 01:51 AM
RLC Circuit Help! stupidlogic Homework Help 7 08-30-2010 02:38 PM
Time Delay Circuit - Door Buzzer hotbpgirl Homework Help 6 07-22-2010 04:10 PM
Cold Plasma Circuit ablaty The Projects Forum 7 11-08-2009 05:31 PM
Need help with momentary to constant circuit with buzzer wh16923 The Projects Forum 3 03-06-2009 07:28 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
