Steady hand buzzer game
Discussion in 'Homework Help' started by craig736, Jan 5, 2014.
  1. craig736
    Jan 5, 2014
    Hello. Sorry this is a very simple question. I have built a steady hand buzzer series circuit for my son. I am using a 9V battery and a buzzer. When I test the circuit using standard copper wire the circuit work and teh buzzer goes off. However when I replace the wire with 2 mm copper cable the buzzer does not go off. Any advice pse
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    Is the copper cable isolated?
    Perhaps a picture of both might give us more info.
    If so, the buzzer won't go off.
    You will need un-isolated wire for the game.
    Bertus
  3. craig736
    Jan 5, 2014
    The copper cable isn't insulated. The only thing I can think of is that it's something to do with the lower resistance of the copper cable because it works with the copper wire. Would that make a difference?
    Picture attached. Hopefully!
  4. #12
    Nov 30, 2010
    16,705
    7,358
    It looks right. If the new wire is not coated with transparent enamel like a transformer would use, you have simply gotten a bad connection somewhere...or maybe the light bulb burned out?
  5. KJ6EAD
    Apr 30, 2011
    1,426
    364
    Similarly to #12, I'm guessing that you have a screw terminal tightened down on insulation (enamel or PVC) instead of bare metal.
  6. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    You can test if the wire has this enamel coating by holding the testpins of a DMM on the wire using the continuity test and hear if the beeper goes of the DMM.
    Bertus
  7. craig736
    Jan 5, 2014
    Thank you both. I'm reckoning it has a thin plastic coating over the copper cable. I'll get to it with emery paper tomorrow.
  8. Metalmann
    Dec 8, 2012
    700
    223
    Sometimes, I'll use a cigarette lighter to burn off insulation on small diameter wires. Just don't hold it there very long.
  9. djsfantasi
    Apr 11, 2010
    2,914
    881
    Or I will go to a craft's store, like Michaels, and buy a roll of bare copper wire.
  10. #12
    Nov 30, 2010
    16,705
    7,358
    2mm resembles 12 gauge American. Just strip some house wiring wire to get naked copper. Got a leftover hunk of it in the shed?
