hi , I read some literature about analogue multimeter, in the website all about circuits, on the following link. I wanted to know about ohms scale in an analogue multimeter, which uses needle reading
file://localhost/C:/Documents%20and%20Settings/munsif/Desktop/Voltmeter%20usage%20_%20BASIC%20CONCEPTS%20AND%20TEST%20EQUIPMENT.mht
Set your multimeter to the highest resistance range available. The resistance function is usually denoted by the unit symbol for resistance: the Greek letter omega (Ω), or sometimes by the word "ohms." Touch the two test probes of your meter together. When you do, the meter should register 0 ohms of resistance. If you are using an analog meter, you will notice the needle deflect full-scale when the probes are touched together, and return to its resting position when the probes are pulled apart.
my comments
___________
I set the multimeter to the highest resistance range, and touched both the test probes together, but needle did not deflect the full scale. I purchased a very simple smallest needle multimeter. it does not use battery. please i need your reply
munsif ali from pakistan
my comments
___________
