Active-reactive power control for a doubly-fed induction generator
Jadetay
Joined Nov 21, 2010
Dear All,
I had completed model that controlled the Active-reactive power of a doubly-fed induction generator for wind turbine.
But then i unable to get the result i want like
1. P&Q generated by stator is different from desired P*&Q* values.
Can anyone help me check my model?
Note: assume stator side is synchronous with grid (power supply)
Thanks you very much!
Jade
Jadetay
Joined Nov 21, 2010
Can anyone help me spot the errors that i had made? I really don't know what's wrong. Thanks you very much.
thatoneguy
Joined Feb 19, 2009
6,359
Maybe use less "buzzword bingo" words in the title and you may get more responses.
Adding the schematic/images inline as attachments will also help a lot in input. Many/most here are wary of downloading a .zip file.
Wendy
Joined Mar 24, 2008
23,797
I don't use access, and I don't even know (or care) what a .mdl file is. I'm not willing to use them either.
