active&reactive power
Discussion in 'General Electronics Chat' started by goutham249, Jul 20, 2006.
  1. goutham249
    Mar 13, 2006
    I have two questions to ask
    first.
    what is difference between active power(P) and reactive power(Q). why dont arithmetic sum P+Q doesnt give apparent power S. Why should they be added (P^2+Q^2)^0.5. please give me the answer with physical interpretation.
    second
    what is differnce between resistance and reactance. why dont a resistor has reactance. while inductor and capacitor has internal resistance
  2. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Active power is the true power loss from a component, i.e. power loss through the energy conversion process to heat due to current flow. This type of power loss is due to resistance. Inductors and capacitors do not exhibit this type of power loss since they store energy as opposed to dissipating heat, however they do produce a voltage drop across the devices giving the impression of true power loss - this is known as reactive power.
    As for the reason that the apparent power is equal to (P^2+Q^2)^0.5 is due to the concept of the power triangle, where the apparent power is the magnitude of the hypotheneuse of a right angled triangle, and the other two sides are the true and reactive powers respectively (positioned at right-angles to each other).
    A good diagramatical explanation can be found here.
    Dave
