I've been using my PicKit2 all weekend. I went to flash a new program onto a chip and I got the "PicKit 2 not found. Check USB connections and use Tools --> Check Communication to retry."
I've hit "tools, check communication" and I get the same thing. The PicKit2 is for sure connected to the the USB port. The green "Power" light is even on.
I found the website linked below and noticed that the "calibrate vdd" option from the tools menu option is greyed out - so even if that would have worked it's not an option.
For what its worth, with the USB plugged into the computer I have 0 volts across all pins.
I don't know what's wrong, because I had been using it without a problem earlier.
An internet search provided little help here.
Thanks in advance!
EDIT: FYI: I have reinstalled PicKit2 software and I am still having the same problem.
web link: http://www.auelectronics.com/Q4.htm
Thanks in advance!
