Thevenin Theorem.Need Help!!!
ELECTRONERD
Joined May 26, 2009
1,147
Let's start with deciding an analysis method. Thevenin's theorem simply states that any complex network of resistors, voltage sources, current sources, etc. can be simplified to a single voltage source in series with a resistor. We may use any analysis method (nodal analysis, mesh analysis, source transformations, etc.) to analyze your circuit. Which analysis method do you prefer?
ayide048
Joined Jun 2, 2010
6
im not really sure because im studying circuit in japanese, i use method which
I=E/Ri+R
calculated
Ri= 1/(1/4+1/4) = 4/3Ω
R= 12
but i dont know how to determine the open circuit voltage..
so...
Jony130
Joined Feb 17, 2009
5,598
Find Vth by any method you prefer to circuit analysis by remove from the circuit 12 Ohm resistor.
To find Rth
1. Replace voltage sources with short circuits and current sources with open circuits.
2. Find equivalent resistance seen at AB point.
The Electrician
Joined Oct 9, 2007
2,986
Have a look at this:
http://www.allaboutcircuits.com/vol_1/chpt_10/8.html
and this:
http://en.wikipedia.org/wiki/Thévenin's_theorem
In your circuit if you remove the 12Ω resistor from the a-b terminals, and then replace the 80 volt source with a short circuit, and the 8 amp source with an open circuit, the resistance looking into the a-b terminals will be 4Ω; this is Rth (or Req).
To calculate the open circuit voltage, notice that the 2Ω resistor has no effect. Then calculate the voltage drop across the 4Ω resistor. If the 12Ω resistor is absent, how much current will there be in the 4Ω resistor? If you know the current in the 4Ω resistor, you know the voltage drop across it. That voltage drop is in series with the 80 volt source, so what will be the voltage seen at the a-b terminals? This will be Vth (or Veq).
Finally, if you know Rth and Vth, what is the value of Vth/(Rth + 12)?
Jony130
Joined Feb 17, 2009
5,598
Becaues to find Rth we replace voltage sources with short circuits and current sources with open circuits.
Ans in your circuit 12Ω resistor is in series with current source.
JimmyB
Joined Jun 1, 2010
38
is there an easy way of finding Eth with kirchoffs laws? I have found it with mesh/nodal analysis, which would be the best way of finding Eth??
Jony130
Joined Feb 17, 2009
5,598
To find Eth we disconnect the load resistor (12Ω)
So we end up with simple circuit where all components connect is series.
And in series circuit the current through each of the components is the same.
In in our circuit the current that will be flow is equal 8A.
So A-B
terminals voltage is equal 80V plus voltage drop across 4Ω resistor.
So only thin we must do to find Eth is to use Ohms law to fond voltage drop on a 4
Ω resistor.
dacart
Joined Jun 7, 2010
13
So A-B
Ω resistor.
I'm trying to teach myself using the Horowitz and Hill text along with the Student Manual. I've been following this problem and Jony's explanation finally brought me to the answer. Thank You!!!!! The only problem I have is that it seems unintuitive (to me) to ADD the voltage drop with the 80V. I would want to subtract it. Cold someone explain the reasoning behind that? If it upsets the thread you can contact me privately. Thanks Again!!!
Dan Carter
t_n_k
Joined Mar 6, 2009
5,455
Dan Carter
If you measured the voltage across the 4Ω resistor what polarity would it have? Would the top be more positive than the bottom or vice-versa? Mark the polarity you expect on the 4Ω and compare that with the polarity of the 80V source. Would the voltages add or subtract? If they have the same sense [top more positive than bottom on 4Ω] then they would add.
What polarity do you expect across the 4Ω?
t_n_k
Joined Mar 6, 2009
5,455
what do you mean by this?? no effect on what?
The Electrician is correct to say this.
In calculating the open circuit voltage across a-b it doesn't matter whether the 2Ω is there or not.
In fact if you think about it, you can ignore it for the whole exercise ....
JimmyB
Joined Jun 1, 2010
38
Can you show why? I can see why by using nodal anlysis and mesh analysis, is there another method??
The Electrician
Joined Oct 9, 2007
2,986
If you have a voltage source with a resistor across it, it can be ignored as far as its effect on the rest of the circuit. Its only effect is to draw some extra current from the voltage source, but that current only passes from the voltage source into the resistor in parallel with the voltage source. It has no effect on the rest of the circuit.
Similarly, a resistor in series with a current source causes some extra voltage drop in the branch containing the current source and the resistor in series with it, but it does not change the current coming from the current source. It has no effect on the rest of the circuit (except perhaps for some very unusual circuit topology).
