intel memory addressing(effective address or offset) in 16 bit protected or real mode
logicman112
Joined Dec 27, 2008
69
Intel-desktop processors like core to quad, i7....
My question is how we can write effective address in 16, 32 or 64 bit modes. We know that the following is a valid effective address in 16 bit IA-32 protected:
[BX+SI]+disp8
Can we specify: [BH+SI]+disp8 as an address?
Also suppose we write a code for IA-32 protected, the following is a valid effective address:
[EAX]+disp32
But is , [AX]+disp32 a valid valid effective address? how about [AL]+disp32?
In real mode(16-bit) we have [BX]+disp8 but is "[BL]+disp8" valid?
And my last question is that how you write a valid address in 64 bit mode?
311499
Joined Apr 29, 2010
5
[BX+SI]+disp8
For the 80286 and 80386, [BX+SI+disp8] is valid. [BH+SI+disp8] is not.
As far as I know, no x86 processors support 8 bit registers as part of
the effective address.
[EAX]+disp32
Again, the address [AL+disp32] contains an 8 bit register and is not valid
on the 80386. [EAX+disp32] on the other hand, is supported by the 80386.
[AX+disp32] is not valid on the 80386.
I'm not familiar with the 64 bit mode of newer processors.
[BL+disp8] contains an 8 bit register and is not a valid effective address on
the 80286 or 80386.
logicman112
Joined Dec 27, 2008
69
it seems that effective address is considered by some specific registers in different code segments. Like in 32 bits, [EAX] is valid and instruction format is decoded by using EAX and no format exists for AX.
in 64 , default is 32 and we can use EAX, EBX,... but with REX.w=1, we can use [RAX], i mean CPU considers RAX when decoding the instruction.
If i am wrong please let me know. Thank you.
