A question that comes up in the forum, especially from people building a transformer/rectifier power supply, is: "What is my meter measuring?"
True RMS DMMs are becoming more common, even at moderate prices, but it may not be clear just what their capabilities are.
Those of us who have been in the business for years usually have a collection of instruments, but the beginner may only have a DMM. So, I thought I would find a way for a beginner with just a DMM to determine what his meter can measure.
This method won't distinguish an average responding, RMS indicating meter from a true RMS responding meter.
The idea is to measure an AC voltage and then compare that reading with the same voltage that has been full wave rectified.
See the attachment. Use a transformer with a convenient output voltage, say at least 12 volts, but higher is better.
Using circuit 1, measure the output voltage. This voltage is just the transformer voltage, with two diode drops in series to compensate for the two diode drops the bridge rectifier will insert. Call this voltage the reference voltage.
Now use circuit 2, and measure the output of the bridge rectifier. This voltage has a DC component and a meter which measures true RMS AC+DC will give a different reading than one that only measures the AC component.
As an example, I used a transformer with a nominal 24 VAC output and measured circuit 1 with a Fluke 189 meter. This is the reference voltage and I got a value of 25.86 VAC.
I then measured circuit 2 with 3 different settings of the meter and got the following values:
DC 23.01
AC only 11.88
AC+DC 25.88
Your meter may not have separate AC and AC+DC modes; if so, they you will have only one reading for RMS AC.
Divide the readings you got from circuit 2 by the reference voltage (the reading from circuit 1); normalize the readings, in other words. Then, if your meter measures a normalized value about .4352, it is not including the DC component in the RMS measurement. In other words, it's "true RMS AC only", not "true RMS AC+DC".
The values I got are shown below, along with their theoretical values if the measured voltage were a distortion free sine wave. Actually, the grid voltage is somewhat flat-topped these days, which causes a deviation from the theoretical value.
The AC+DC value measured from circuit 2 should be identical to the value from circuit 1.
This method allows a person to tell whether their meter can measure a true RMS voltage which includes the DC component.
DC 23.01
AC only 11.88
AC+DC 25.88
Rich (BB code):
Normalized Theoretical
Values Value
DC .8891 SQRT(8)/pi .9003
AC only .459 SQRT(PI^2 -8)/PI .4352
AC+DC 1.000 1.000
