RPM meter - how does it work?
EB255GTX
Joined Apr 30, 2011
62
HI folks,
i am looking for a nice big analog meter for a project, i want to run it from DC volts - the exact magnitude is not too important as i can scale either the meter series resistor (assuming a standard permanent magnet voltmeter) or the voltage itself with circuitry if needed.
I see this nice big meter on ebay, the question is- what is the input to an RPM meter likely to be? Yes, i have asked the seller but no response yet and they may not know anyway.
I know automotive RPM meters generally take a pulse - if that's the case, is the meter RC filtering the pulses to get a DC level and then the mechanism is just a standard voltmeter or is there a more complicated mechanism around?
The seller does say int he listing "can be used as a standard analog meter"
thanks for any tips!
It could very well be a basic movement. The deal is with a series resistor, you get a DC voltmeter. Shunts combines with a DC voltmeter give you an ammeter.
50 uA FS used to be a standard. You really won't know until you take it apart.
Without any resistors, it's a basic movement, In order to find what resistor you need to deflect full scale, you have to measure the resistance INDIRECTLY. Use a small battery, a potentiometer (set at max resistance). You;ll have to use trial and error to use the potentiometer to deflect exactly 1/2 scale. Also measure the voltage at 1/2 scale. Remove the resistor and measure it, It will be the resistance of the meter movement.
A=2*V/R(pot) will be the FS current of the meter.
From those numbers, you can make it read voltage or current with external resistors.
EB255GTX
Joined Apr 30, 2011
62
Thanks for the info - it will come in useful if i buy the meter and adapt it for my project :)
What do you think the chances of it being a normal meter movement are - it's the fact that it is an RPM meter that is worrying me, i don;t want to spec $100 and find that it only works on pulses or something....
Hopefully the seller responds and it's just a normal voltmeter-i don;t care what the scale says as i will replace that with a custom one but my driving circuit can only output a variable DC level (filtered PWM from a micro).
thanks!
Sensacell
Joined Jun 19, 2012
3,453
Since there is really no such thing as a "standard RPM meter" I would be wary of buying it without concrete technical specs.
Since you are replacing the scale anyway- just buy a standard analog meter? Then you know what you are getting.
He did say "tested", so he had to test using something, right?
The old tach/dwell meters had that sort of movement.
There should be plenty of resources for calculating the series resistor needed for a particular movement. Finding the resistance value of the movement was well known in my day as a kid. 50 ua, 1 mA and -1-0-+1 mA were common "movements".
#12
Joined Nov 30, 2010
18,224
I'm here to tell you that you don't have much to worry about. The age of those meters tells me they aren't crammed with digital processors. In addition, a pulsed input will be averaged by the mass of the meter movement. Just be really careful about testing it to find its specs. These are in the microamp range for current. I'm thinking a 1.5V battery with 30 thousand ohms in series with it will cause enough current to be in the danger zone. Try figuring for 25 ua, then sneak up on that amount of current. The answer might be as high as 1 milliamp, but don't bet on it. Start with 1% of 1 milliamp.
EB255GTX
Joined Apr 30, 2011
62
So -
I purchased the meters, and they work just fine for what i want to do i.e. 0-5V by way of PWM from a micro.
interesting thing, they have a small (in value) inductor internally as per the attached pic. Even with the inductor shorted, the meter movement is quite damped, i am not aware of physical means to do this, does anyone know of some trickery in this area e.g. some sort of damped permanent magnet meter movement?
Its not physically binding, the needle moves freely and there are two identical meters that behave the same way.
Very interesting....
Anyway i post this comment in order to followup - thanks to all who replied :)
BillB3857
Joined Feb 28, 2009
2,571
Damped meter movements, at one time, simply used an aluminum bobbin to wind the meter coil on. The aluminum, being conductive, acted as a shorted turn. When moved in the magnetic field of the meter, the current created in the bobbin set up an opposing field which damped the movement.
debe
Joined Sep 21, 2010
1,390
Looking at the picture of your meter, its just a analogue meter. I have built several Tachos using the IC, LM2917 as suggested by Max. They only use a few parts & simple to get going & work great..
EB255GTX
Joined Apr 30, 2011
62
Hey.... might be something along these lines-thanks for the tip!
ian field
Joined Oct 27, 2012
6,536
HI folks,
There was the TI SN76810 speedo/tacho chip - but its getting hard to find even archived datasheets nowadays.
Basically you feed a moving coil meter with a gated constant current source. That is gated by a fixed on period monostable.
The pulse shaper depends on what pickup transducer - you just want narrow (spike) pulses to trigger the monostable.
ian field
Joined Oct 27, 2012
6,536
There is also liquid damping, but probably not in a tachometer.
The speedo company I worked for manufactured their own meter movements, damping was a drop of thick silicone oil on the pivots.
Using an off the shelf moving coil movement - a big fat foil capacitor across the terminals is much easier.
Not a bad idea to make sure its discharged first though!
