All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 09-17-2006, 10:59 PM
Jeremy Jeremy is offline
Question Help wiring a timer switch
I appologize if this is too elementary for most of you but if anyone can offer some advice I'd most appreciate it. I have a fan that plugs into a standard 120V outlet (3 pronged plug) that I want to control with a timer. I found a very nice timer that's desinged to replace a wall switch (ie, for controlling lights). What I wanted to do is mount it in a dual outlet box next to a 3 pronged outlet and wire in a 3 pronged cord. That way I'd have a "timer box" that I could plug into any outlet in the house which would then control the fan I plug into it.
What's confusing me is that the timer switch comes with 4 wires (black=hot, white=common, red=load, and green=ground). The cord I want to wire in to the switch obviously only has three wires (black = hot, white = common, green = ground) which matches the way I undestand that wall switches get wired. So how do I wire a three pronged plug and outlet to a 4 wired switch? I had assumed that the switch just used three wires and broke the connection of the hot wire to turn my load on and off but apparently this is not the case. I assume that the solution is to wire two of the four wires together but that is just a guess and I don't intend to do anything without some guidance from someone who knows what they are doing. I am very confused and don't want to do something stupid with this circuit!
Thanks for any help.
Jeremy
  #2
Old 09-18-2006, 01:31 AM
Søren Søren is offline
Default
Quote:
The timers black (hot) goes to the phase (hot) of the mains.
The timers red (load) goes to the black (hot) of the switch/fan (as that is the load).
The white is connected to the other white plus to the white from the mains.
The green is connected to the other green plus to the green from the mains.
The timer need to be connected to hot and neutral (what you call common) to work and to ground to be "safe".
To supply the fan, it further needs an output, which is hot when the timer is supposed to drive the load connected to it and hence the four wires.
__________________
Regards,
Soeren
>>> Whatever works... Works <<<
  #3
Old 09-18-2006, 05:20 AM
Default
Soeren,
Thanks very much for taking the time to reply. Yes, you are obviously right. I actually figured it out a couple of hours ago and eveything is working fine. In retrospect I don't know what I was thinking. What was confusing me was the red wire - it took a while for me to realize that it is the "output" hot wire from the switch. It seemed odd that the red wire would go to the load's black wire but once I realized that it made perfect sense. Thanks again for your help!
Jeremy
  #4
Old 09-19-2006, 12:03 AM
Default
Well that happens to us all from time to time - having a problem up close sometimes mean you loose the oversight
Happy "timing".
__________________
Regards,
Soeren
Tags
Related Site Pages
Section Title
Worksheet Electrical noise and interference
Worksheet Basic oscilloscope operation
Worksheet Kirchhoff's Laws
Worksheet Safety grounding
Textbook Wiring Color Codes : Color Codes
Textbook Transformer -- power supply : Ac Circuits
Textbook Setting up a home lab : Introduction
Textbook Multimeters : Dc Metering Circuits
Textbook Safe circuit design : Electrical Safety
Similar Threads
Thread Thread Starter Forum Replies Last Post
Help needed wiring repeat cycle timer? BFG The Projects Forum 9 02-04-2013 05:31 PM
Help With Wiring Timer Switch Spaceghostster General Electronics Chat 6 12-14-2010 01:09 PM
Repeat cycle timer wiring hogan The Projects Forum 0 07-31-2010 09:44 AM
Countdown timer switch jimwells41 The Projects Forum 6 01-08-2009 01:28 PM
Digital timer switch - Geyser sincla1 General Electronics Chat 7 11-07-2008 03:31 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
