please help by wiring a fotek twin timer and relay
Discussion in 'The Projects Forum' started by hnoah, Jun 4, 2011.
  1. hnoah
    Jun 4, 2011
    if any one can help by wiring the timer and a relay and 2 lamps and a switch as stated in the following drawing in case:
    1) it operate a one phase pump
    2) it operate an 3 phase pump
    thanks
    HNoah
  2. williamj
    Sep 3, 2009
    180
    32
    HNoah,
    You really need to provide more information. From your attachment I'm assuming that you want to operate the pumps at different times. Unless the timer itself can handle the single phase pump load (not a good idea) there aren't enought components listed.
    If you really want us help to help you, you're going to have help us help you. What is it that you are actually trying to accomplish? What is the sequence of operation (what happens when?)?
    williamj
  3. hnoah
    Jun 4, 2011
    willamj
    thanks ,
    I have two high pressure pumps (70 par), the first one is drivern by a one phase electric motor and the other is driven by a 3 phase electric motor. I want to use a sepate timer to operate each of them. when I switch the power on - switch key- the the timer will energized the relay to operate the pump for a specified time period say eg 5 mintues , and then it will deenrgize the relay for a specified period of time say for eg 3 mintues. when is pump is operating the green lamp will light and in the stopping period the red lamp will be on. I Just need to know the wiring of the components (twin timer, relay, lamps & the switch key)
    HNoah
  4. williamj
    Sep 3, 2009
    180
    32
    hnoah,
    Still need to know the different voltages, light voltage (12v, 24v, - 120v? ac-dc?), coil voltages (timer and contactor) and pump voltages (single phase and three phase). Not good to cross voltage anything.
    williamj
  5. hnoah
    Jun 4, 2011
    williamsj,
    thanks again,
    Fotek twin timer TDVY-6M =220 VAC
    LS RELAY (GMC-18)=AC220V 50l60 hz
    lamp=220 VAC
    switch= 250 VAC 15A
    125 VAC. 20A
    Hnoah
  6. williamj
    Sep 3, 2009
    180
    32
    hnoah,
    Specifically we need the "coil" voltages for the timer and the contactor. Generally coil voltages are much lower than "relay" or "contact" voltages.
    The reason why relays and contactors came into being in the first place was to control a much larger and more dangerous voltage/current with a smaller and much safer voltage/current. With a contactor you can control a 3 phase 480VAC device with a 12, 24, 48, 90, 120 or even a 220 volt coil. All of which, except for the last two which are generaly AC, can be either AC or DC.
    It all makes a very big difference in how the circuit is wired.
    williamj
