I'm making a behavioral model of BCD to 7-segment decoder. But its does not give the predicted results. The output of all the segments are 'z'.
Here is the result of the simulation
Is there something wrong with my testbench?
Rich (BB code):
module binaryTo7Seg(code, segment);
output reg [7:0] segment;
input [3:0] code;
always@(code)
case(code)
0: segment = ~8'b11111100;
1: segment = ~8'b01100000;
2: segment = ~8'b11011010;
3: segment = ~8'b11110010;
4: segment = ~8'b01100110;
5: segment = ~8'b10110110;
6: segment = ~8'b10111110;
7: segment = ~8'b11100000;
8: segment = ~8'b11111110;
9: segment = ~8'b11100110;
10: segment = ~8'b11101110;
11: segment = ~8'b00111110;
12: segment = ~8'b10011100;
13: segment = ~8'b01111010;
14: segment = ~8'b10011110;
15: segment = ~8'b10001110;
default: segment = 8'bx;
endcase
endmodule
Rich (BB code):
module binaryTo7Seg_test(code, segment);
output reg [3:0] code;
input [7:0] segment;
initial
begin
$monitor($time,,,"A = %b B = %b C = %b D = %b, aSeg = %b, bSeg = %b, cSeg = %b, dSeg = %b, eSeg = %b, fSeg = %b, gSeg = %b, hSeg = %b",code[3],code[2],code[1],code[0],segment[7],segment[6],segment[5],segment[4],segment[3],segment[2],segment[1],segment[0]);
#10 code[3] = 0; code[2] = 0; code[1] = 0; code[0] = 0;
#10 code[3] = 0; code[2] = 0; code[1] = 0; code[0] = 1;
#10 code[3] = 0; code[2] = 0; code[1] = 1; code[0] = 0;
#10 code[3] = 0; code[2] = 0; code[1] = 1; code[0] = 1;
#10 code[3] = 0; code[2] = 1; code[1] = 0; code[0] = 0;
#10 code[3] = 0; code[2] = 1; code[1] = 0; code[0] = 1;
#10 code[3] = 0; code[2] = 1; code[1] = 1; code[0] = 0;
#10 code[3] = 0; code[2] = 1; code[1] = 1; code[0] = 1;
#10 code[3] = 1; code[2] = 0; code[1] = 0; code[0] = 0;
#10 code[3] = 1; code[2] = 0; code[1] = 0; code[0] = 1;
#10 code[3] = 1; code[2] = 0; code[1] = 1; code[0] = 0;
#10 code[3] = 1; code[2] = 0; code[1] = 1; code[0] = 1;
#10 code[3] = 1; code[2] = 1; code[1] = 0; code[0] = 0;
#10 code[3] = 1; code[2] = 1; code[1] = 0; code[0] = 1;
#10 code[3] = 1; code[2] = 1; code[1] = 1; code[0] = 0;
#10 code[3] = 1; code[2] = 1; code[1] = 1; code[0] = 1;
#10 $finish;
end
initial
begin
$dumpfile ("binaryTo7Seg.dump");
$dumpvars (0, binaryTo7Seg_test);
end
endmodule
Rich (BB code):
0 A = x B = x C = x D = x, aSeg = z, bSeg = z, cSeg = z, dSeg = z, eSeg = z, fSeg = z, gSeg = z, hSeg = z
10 A = 0 B = 0 C = 0 D = 0, aSeg = z, bSeg = z, cSeg = z, dSeg = z, eSeg = z, fSeg = z, gSeg = z, hSeg = z
20 A = 0 B = 0 C = 0 D = 1, aSeg = z, bSeg = z, cSeg = z, dSeg = z, eSeg = z, fSeg = z, gSeg = z, hSeg = z
30 A = 0 B = 0 C = 1 D = 0, aSeg = z, bSeg = z, cSeg = z, dSeg = z, eSeg = z, fSeg = z, gSeg = z, hSeg = z
40 A = 0 B = 0 C = 1 D = 1, aSeg = z, bSeg = z, cSeg = z, dSeg = z, eSeg = z, fSeg = z, gSeg = z, hSeg = z
50 A = 0 B = 1 C = 0 D = 0, aSeg = z, bSeg = z, cSeg = z, dSeg = z, eSeg = z, fSeg = z, gSeg = z, hSeg = z
60 A = 0 B = 1 C = 0 D = 1, aSeg = z, bSeg = z, cSeg = z, dSeg = z, eSeg = z, fSeg = z, gSeg = z, hSeg = z
70 A = 0 B = 1 C = 1 D = 0, aSeg = z, bSeg = z, cSeg = z, dSeg = z, eSeg = z, fSeg = z, gSeg = z, hSeg = z
80 A = 0 B = 1 C = 1 D = 1, aSeg = z, bSeg = z, cSeg = z, dSeg = z, eSeg = z, fSeg = z, gSeg = z, hSeg = z
90 A = 1 B = 0 C = 0 D = 0, aSeg = z, bSeg = z, cSeg = z, dSeg = z, eSeg = z, fSeg = z, gSeg = z, hSeg = z
100 A = 1 B = 0 C = 0 D = 1, aSeg = z, bSeg = z, cSeg = z, dSeg = z, eSeg = z, fSeg = z, gSeg = z, hSeg = z
110 A = 1 B = 0 C = 1 D = 0, aSeg = z, bSeg = z, cSeg = z, dSeg = z, eSeg = z, fSeg = z, gSeg = z, hSeg = z
120 A = 1 B = 0 C = 1 D = 1, aSeg = z, bSeg = z, cSeg = z, dSeg = z, eSeg = z, fSeg = z, gSeg = z, hSeg = z
130 A = 1 B = 1 C = 0 D = 0, aSeg = z, bSeg = z, cSeg = z, dSeg = z, eSeg = z, fSeg = z, gSeg = z, hSeg = z
140 A = 1 B = 1 C = 0 D = 1, aSeg = z, bSeg = z, cSeg = z, dSeg = z, eSeg = z, fSeg = z, gSeg = z, hSeg = z
150 A = 1 B = 1 C = 1 D = 0, aSeg = z, bSeg = z, cSeg = z, dSeg = z, eSeg = z, fSeg = z, gSeg = z, hSeg = z
160 A = 1 B = 1 C = 1 D = 1, aSeg = z, bSeg = z, cSeg = z, dSeg = z, eSeg = z, fSeg = z, gSeg = z, hSeg = z
