| The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it. |
Thread Tools | Display Modes |
#1
I need to build something to convert 12 v dc to 120 v ac and can handle more than 1300 w I know you can buy pre built but money is low
#2
I'm pretty sure at these power levels you'll save yourself money buying it from the store. And serious amount of time.
#3
You would be far better off to purchase a commercial unit than to try to build something yourself.
It will wind up being less expensive and more efficient. Just to throw some numbers at you, a power inverter might have around 87% efficiency. So to get 1,300W out will require nearly 1,500W input. (1.3kw/87%=1.5kw) If you're running from 12v batteries, then 1500W/12v = 125 Amperes of current will be required. You would need a large bank of high-capacity 12v deep-cycle batteries to supply 1300W for any length of time. You would also need a means of recharging that bank of batteries. Charging/discharging lead/acid batteries is certainly not a 100% efficient process. More like 70%. Losses in the charger itself are not included. You would need a large and expensive solar array, or very efficient line-powered charger(s) to recharge them. |
#4
You ought to be able to find a used 1500 watt inverter on E-bay, or by canvassing the local garage/ yard sales. If that doesn't work, put an ad in your local paper. Even the local junkyard might have one on the shelf. I just bought a very high class computer controlled Sansui turntable at a local thift store for $25.00. Shop around...high tech devices are as common as mushrooms nowadays.
Cheers, DPW |
#5
thanks that is all I needed to know Ill go pre built
| Bookmarks |
| Tags |
| converter |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Need help on DC/DC buck converter | apis87 | The Projects Forum | 2 | 06-23-2009 08:08 AM |
| How to sync parallel to serial converter to transmit | pigue | General Electronics Chat | 3 | 08-21-2008 03:26 PM |
| D/A converter | forder | The Projects Forum | 1 | 11-07-2007 01:09 AM |
