All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 11-08-2009, 10:28 AM
MIRINGU's Avatar
MIRINGU MIRINGU is offline
Member
Send a message via Yahoo to MIRINGU
Default Amplifier output power-LA 4508
Hi, i've these parameters when i used my multimeter to take the readings of an amplifier using IC 4508 . I, had done all the connections ie from radio input to output speaker when taking data.
Input voltage-12v,500mA. Speaker Output terminal-
R 2.3 ohms,V 0.04 V.
Help me get the total output POWER of the amp.
  #2
Old 11-08-2009, 01:46 PM
SgtWookie's Avatar
SgtWookie SgtWookie is online now
Default
Gee, only about 17.4mA output current through a 2.3 Ohm resistor?
That's about 695 microwatts.
Either you're not making the measurements correctly, the IC is bad, or you have something connected up incorrectly. That IC should be able to output up to 2.5A on one channel - with a proper heat sink, of course.
  #3
Old 11-08-2009, 03:39 PM
Audioguru's Avatar
Audioguru Audioguru is offline
Default
With a 12V supply its max linear output swing is only 4V peak which is a current of 1.25A into a 3.2 ohm impedance speaker. Its power is 2.5W at clipping into a 3.2 ohm impedance speaker.
You could bridge its two outputs to drive 5W at clipping into a 6.4 ohm speaker.
  #4
Old 11-08-2009, 06:35 PM
MIRINGU's Avatar
Member
Default
I was using a 3W,4¤ Speaker.
Audioguru, what does bridging the outputs mean?
  #5
Old 11-08-2009, 09:40 PM
Audioguru's Avatar
Default
Bridging the outputs of power amplifiers is when one amplifier drives one wire of a speaker and a second amplifier connected with reverse phase drives the other wire of the speaker. The speaker has each wire driven push-pull. Then an output coupling capacitor is not needed and the voltage swing to the speaker is doubled which results in much more power.
Car radio amplifiers are usually bridged.
  #6
Old 11-09-2009, 04:53 AM
MIRINGU's Avatar
Member
Default
Thanks 4 you replies
Bookmarks
Tags
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Power transformer and amplifier Rating bonjing Homework Help 10 08-11-2009 04:12 AM
Multistage amplifier power question athos Homework Help 3 11-22-2008 08:02 PM
For a ups what is the meaning of its input & output power factor? wkyong General Electronics Chat 1 05-01-2008 03:05 PM
What is the command to view output power in a PSpice simulation? Amenably_Amendable Homework Help 0 01-28-2008 11:42 PM
Class E Power Amplifier Design RFBeginner The Projects Forum 1 05-07-2007 07:03 AM
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Copyright © 2009, All About Circuits. All Rights Reserved.
