All About Circuits Forum
Go Back   All About Circuits Forum > Software, Microcomputing, and Communications Forums > Embedded Systems and Microcontrollers
Embedded Systems and Microcontrollers Discussion forum for projects and working with embedded systems and microcontrollers (FPGAs, PICs, AVRs). Get help with hardware issues and embedded programming.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 11-04-2009, 01:52 AM
patheticz patheticz is offline
Junior Member
Default Clock frequency
How do i generate a clock frequency for a FPGA chip?
beside using a crystal
  #2
Old 11-04-2009, 02:06 AM
Papabravo's Avatar
Papabravo Papabravo is offline
Default
I dunno -- What are your requirements for frequency, stability, accuracy et cetra. How can we answer your questions if you fail to supply any information?
__________________
We never have time to do it right,
But we always have time to do it over.
  #3
Old 11-04-2009, 02:09 AM
beenthere's Avatar
beenthere beenthere is offline
Super Moderator
Default
Get a TTL or CMOS oscillator. Mouser and Digi-Key carry a wide selection.
Here is a link to a manufacturer so you can get an idea of the frequencies available - most are standard -http://www.well.com/~oe/OscFreqs.html
__________________
First comes the hardware, then the software.
  #4
Old 11-04-2009, 02:19 AM
Papabravo's Avatar
Default
You can also use a PLL, divider, and a VFO
__________________
  #5
Old 11-04-2009, 04:57 AM
Junior Member
Default
Sorry for the lack of information
First of all, the query arose because i am designing an embedded controller for a a power switching module that is supposed to be able to function at swtiching freq of at least 10kHz.
then i was looking through the specification sheet and realized that the Virtex 5 and virtex 6 FPGA can operate at 400MHz -1000MHz.
Therefore, i was not sure what methods can i use to generate signal for the clock if i am going to use either of the FPGA
  #6
Old 11-04-2009, 05:14 AM
Papabravo's Avatar
Default
Those frequencies are maximums. There is absolutely nothing that says you have to operate at such frequencies. In any case the way you genrate 10 kHz from a crystal or other type of oscillator is to pick a convenient frequency and divide it down.
__________________
  #7
Old 11-04-2009, 05:55 AM
auri_z's Avatar
auri_z auri_z is offline
Default
it depend your requiments,if you need stability use crystal if not oscilator from some R and C can make it..
  #8
Old 11-05-2009, 12:25 AM
Junior Member
Default
Quote:
i am a bit confused here.
does that mean by having an oscillator of 10kHz, i can also generate frequency that is higher than that?
  #9
Old 11-05-2009, 01:24 AM
Nanophotonics's Avatar
Nanophotonics Nanophotonics is offline
Default
Quote:
No, you always generate a lower clock frequency from a higher one.
__________________
Everything is relatively defined. Transistors in circuits are biased, leave our mind unbiased.
  #10
Old 11-05-2009, 02:02 AM
beenthere's Avatar
Super Moderator
Default
I gave you a bad link. Try Maxim - http://para.maxim-ic.com/en/search.m...XO&tree=clkgen
__________________
Bookmarks
Tags
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
50/60Hz Frequency conversion using PIC eblc1388 The Projects Forum 3 07-07-2009 03:46 PM
Amplifier Measurement PRS General Electronics Chat 24 05-18-2009 12:17 AM
Low frequency LFO with a DVM meter? relicmarks General Electronics Chat 14 05-03-2008 07:50 PM
PWM and clock frequency tyc8159 Embedded Systems and Microcontrollers 3 05-22-2007 02:51 AM
Clock Frequency limiter bigbigblue General Electronics Chat 6 04-06-2006 11:41 PM
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Copyright © 2009, All About Circuits. All Rights Reserved.
