All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Homework Help
Notices
Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 08-01-2006, 02:11 PM
Steve1992 Steve1992 is offline
Member
Default Calculating Inductance
Ive been using complex numbers and my scientific calculator to great
success as shown in this sites tutorial. I like the why I can just use ohms law, as with DC analysis.
But how do I calculate the inductance without going back to trig.
Parallel R-L ac circuit:
"Resistor 40R;
Supply 200V, 50Hz
Supply current is 8A.
Inductor, L?
Whats the inductance of the coil, L?"
  #2
Old 08-01-2006, 03:35 PM
beenthere's Avatar
beenthere beenthere is offline
Super Moderator
Default
No Trig, just simple algebra.
I = E/R, using the 40 ohm resistor, will give you something other than 8 amps. R = E/I will give you the resistance of the paralleled resitor and inductance. Figure the correct resistance to parallel with 40 ohms that give the 8 amps of current. Then, using L = RL/2piF, you have the inductance.
Bookmarks
Tags
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Calculating frequency darbyrne Homework Help 2 12-07-2006 11:43 AM
mutual inductance problem JesterElectronics General Electronics Chat 1 10-21-2006 03:04 PM
AC theory - Inductance Steve1992 Homework Help 3 08-05-2006 01:19 PM
Problems with the mutual inductance superdani884 General Electronics Chat 1 08-02-2005 10:10 AM
Paradox of Ground Lead Inductance RyanP General Electronics Chat 4 08-17-2004 03:00 AM
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License. Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
