Calculating inductance of single layer aluminum cylidrical coil
Discussion in 'The Projects Forum' started by pafrazier, Mar 4, 2013.
  1. pafrazier
    Thread Starter Active Member
    Jun 4, 2011
    57
    How can I calculate a single wound aluminum wound coil? Can you refer me to an online calculator that I can input for aluminum opposed to copper. I assume that the inductance will be different?
  2. w2aew
    Member
    Jan 3, 2012
    219
    64
    Inductance will be the same. Q will be slightly different due to different material properties.
  3. crutschow
    Mar 14, 2008
    13,481
    3,368
    Inductance is determined by the geometry of the current path in space. It makes no difference what is carrying the current.
  4. pafrazier
    Jun 4, 2011
    57
    Great. Thanks for your help.
  5. pafrazier
    Jun 4, 2011
    57
    HI,
    Is it safe to assume that the self capacitance will be the same as well?
  6. crutschow
    Mar 14, 2008
    13,481
    3,368
    For the same coil geometry and wire size, yes.
