Admittedly, I am new to this stuff, but I find one really frustrating problem with the datasheet websites. Maybe someone here has an answer.
The problem is that many components do NOT have the full component number on them! So if I look at the component, write down the number, and then go to the datasheet archive, it says "no results". On the other hand, if you can find the schematic, where they give the complete number, then the datasheet archive can find it. So why don't the archive people realize this and provide a better search capability?
Here's an example:
An old audio receiver from the '70's has a bunch of transistors labelled "C1918". This will give the old "no results", but when I found the schematic which indicates the full designation of "2SC1918", then the archive can help.
But WHY not give search results for anything that matches "C1918" to start with?
Here's an example:
