Voltmeter design problem, please help
soliloquy
Joined Aug 16, 2009
This is our question :
Design an analog multimeter with a panel meter that has a full scale deflection dc voltage rating of 15V and an internal coil resistance fo 100Ω. The multimeter must be able to measure :
1) voltage range from 1mV to 1000V
2) current range from 10mA to 5A and
3) resistance range from 0.1Ω to 100MΩ
Describe in detail all the designing steps and calculations
MY problem is
For the Voltmeter design
http://www.allaboutcircuits.com/vol_1/chpt_8/2.html
the site only shows us how we can add mutiplier resistors to measure bigger voltages, but how about smaller voltages ;
in my case 1.5 mV to 0.15V ?
tried adding parallel resistors, but this only divides the current and the voltage remains the same,
we need a I = 0.15Ampere for full scale deflection (fsd) but adding parallel, the current that passes through the internal coil resistance of meter is too small therefore only a small deflection will be seen (not sensitive)
how do i solve this? diagrams would be much appreciated =)
If you want to go beyond the resolution (in terms of lower voltage/current) you need to fool the instrument.
You must amplify the signal before you feed it to the instrument.
Ciao,
Mauro
rspuzio
Joined Jan 19, 2009
77
> of 15V and an internal coil resistance of 100Ω
It sounds like there is something missing in this description, namely
the series resistor. A panel meter by itself is a microammeter, for
which a resistance of 100Ω sounds typical. In order to get the meter
to read 15V, you are supposed to connect a fairly large resistor in
series with the meter movement. To proceed further, you need to
find out what the value of this resistance is. With that information
in hand, you can then calculate how many microamps it takes to
deflect the needle fully, then figure out what sizes of resistors are
needed to provide the ranges.
As a mater of fact, this sounds a lot like the Radio Shack panel
meter. Looking at the back of the package of such a meter, I
see it says the following:
15 VDC full scale deflection
85 Ω internal resistance
15 kΩ resistor should be connected between meter and voltage being measured
By Ohm's law, 15 V across a 15 kΩ resistor makes 1 mA flow, so
that means that the full scale deflection of the meter movement
occurs at 1000 μA. (By the way, this means that this is not a
very sensitive meter --- a value like 50 μA or less would be
typical for a more sensitive meter. Put another way, this meter
has 1 kΩ/V, which limits its use to circuits with large currents
flowing through them and makes it worthless for fine electronics
without amplification.)
Have another look at your homework to locate information
which would let you figure out how many microamps are
needed to deflect the needle across the full scale. If no such
information is provided, point out to your teacher that you can't
finish the assignment because of inadequate specs.
JoeJester
Joined Apr 26, 2005
4,390
It the amperage of the meter isn't indicated, we certainly can infer it from the lowest voltage scale and the coil resistance. From there, you can work through all the details one by one.
I posed the question so the OP is aware of a starting point, inferred or not.
