I'm an experienced programmer, but I'm just venturing into electronics. I'm building a circuit based on an Amtel atmega168 to measure both voltage and the current drawn by a load. Specifically it will be connected between a pedal powered generator and a charge controller for charging lead acid batteries. I've cobbled together a circuit design from several internet sources and I'm looking for some feedback on it.
If you guys could give any tips on if the circuit is sufficient and if not on ways to improve it I'd be very much appreciative. See the attached for a schematic.
