| Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help. |
Thread Tools | Display Modes |
#1
Hello.
I have APC back UPS BE650Y-IN (Model: http://www.apc.com/products/category...13&segmentID=1 select BE650Y-IN from first pulldown menu to see the specification). Its battery is dead now. I have solar system in home. At present it is used for only lights. Solar system has the battery which looks something like this (http://www.apexbattery.com/8a22nf-so...batteries.html). Now I want to connect the APC UPS to this battery. Is this connection possible?. UPS battery is 12V,3A and Solar battery is 12V,6A (Dont know exactly). Will this connection cause any problem to UPS?. I want to use this UPS for only TV(90W). |
#2
The biggest problem is the power of the TV. 90 watts is not much at 120 VAC, but to supply 90 watts from a battery of 12 volts will require 7.5 amps of current. The inverter is not perfectly efficient, so plan on needing a battery that can supply at least 8 amps.
__________________
First comes the hardware, then the software. |
#3
Quote:
I was running TV with the same UPS(old battery 12V, 3A) upto 45min before its battery bacame dead. Now I planned to go for 12V,6A battery. Since there is only change in AMPs, I thought there may be some problem of more heat generation which requires additional heat sink. |
#4
Quote:
On our RV we couldn't figure out for the longest time how to run the home theater system and get a proper run time without draining the main batteries. After a lot of research we decided to modify an APC Smart UPS 1400 by removing the internal batteries and adding 2x 12v 75ah batteries. Now the home theater system runs for almost 20 hours before needing to be plugged in. I would recommend this approach to anyone. Gives you a much longer run time than the manufacturer and still gives you all the protection. Joe |
| Tags |
| apc, battery, connecting, solar, ups |
Related Site Pages
| Section | Title | |||
| Worksheet | Open-loop opamp circuits | |||
| Worksheet | Th'evenin's, Norton's, and Maximum Power Transfer theorems | |||
| Worksheet | Batteries | |||
| Worksheet | Sources of electricity | |||
| Worksheet | Electrical connections | |||
| Video Lecture | Electrical Quantities A - Basic Electronics and Units of Measure | |||
| Textbook | The common-emitter amplifier : Bipolar Junction Transistors | |||
| Textbook | The transistor as a switch : Bipolar Junction Transistors | |||
| Textbook | Special-purpose diodes : Diodes And Rectifiers | |||
| Textbook | Battery ratings : Batteries And Power Systems | |||
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| solar powered smart battery charger | salamander27 | The Projects Forum | 21 | 05-28-2009 11:13 PM |
| Solar Panel to charge CPAP LI-Ion Battery - Voltage Regulator Problem | regulatorshmegulator | The Projects Forum | 6 | 04-03-2009 11:58 AM |
| Help A Newbie Make His First Circuit; Solar Battery Charger | woodjac | General Electronics Chat | 5 | 11-12-2008 04:25 AM |
| solar battery charger for cell phone | solarman | The Projects Forum | 0 | 08-11-2008 12:10 PM |
| Thread Tools | |
| Display Modes | |
